Hairline crack on radiator? Check video
Old Jul 6, 2011 | 07:58 PM
MoreCowbell's Avatar
Default Hairline crack on radiator? Check video
So today I drained the fluid, flushed with water. Then added the flush and water and drove around for 15 minutes with the heater on and full blast.. I noticed bubbles from the top. Is it cracked? And can i or should I JB weld it right there for a temp fix? Advice greatly appreciated thanks!
http://www.youtube.com/watch?v=Y-yIxwkoAGA
Old Jul 6, 2011 | 08:03 PM
PunkRudeBoy's Avatar
Default Re: Hairline crack on radiator? Check video
Mine was doing the same thing i just replaced it. Cost me about 70 bucks and took an hour or so to install.
Old Jul 6, 2011 | 08:04 PM
frankenghia's Avatar
its gone. Jb weld wont do anything. The crack will just continue. Time to replace it...
Old Jul 6, 2011 | 08:21 PM
hyperblu's Avatar
You flushed the gunk that was probably sealing it in the first place... Just replace it.
Old Jul 7, 2011 | 04:19 AM
Thanks for the help all!!
Old Jul 7, 2011 | 10:50 AM
Slacker93eg's Avatar
10 Year Member
In the event of an emergency if you were stuck somewhere, you could use an egg or black pepper in the radiator to help seal the crack.
Old Jul 7, 2011 | 10:54 AM
kaiba's Avatar
Always wanted to try the egg trick.
Old Jul 7, 2011 | 11:10 AM
10 Year Member
My buddy did it when he overheated when we were on a camping trick, got him home 150miles away
Old Jul 7, 2011 | 11:23 AM
Thanks for the extra tips as well. I just ordered a radiator last night and was tuning this up for a camping trip in 5 days so if I can't replace it in time I will use the egg trick if it cracks on the way there or back.
Will report back if I use the trick by the way.
inaety
Aug 4, 2011 04:15 PM
tbonez
Feb 9, 2007 05:53 AM
slikz714
Jul 12, 2006 03:40 AM
fc3sol
May 4, 2004 10:40 PM
geminis2k
Sep 16, 2002 06:06 PM
