what clusters fit 2000 si?
Old Jul 6, 2011 | 04:09 PM
jumpin4abeat's Avatar
Default what clusters fit 2000 si?
So I think my cluster is bad because when i disconnect the vss the speedometer stays at 20mph, connected or not. I changed the vss thinking that was the problem but i think its the cluster since it does not change if disconnected. I was curious on what cluster will fit? Like a lx cluster, integra cluster?
Old Jul 6, 2011 | 04:16 PM
hyperblu's Avatar
Default Re: what clusters fit 2000 si?
Si,SiR,Spoon,Mugen,any ek cluster... crv clusters are interchangable i believe also....
Old Jul 6, 2011 | 05:02 PM
are there any integra clusters that will fit?
Old Jul 6, 2011 | 05:05 PM
hyperblu's Avatar
with some modifications...
Old Jul 6, 2011 | 05:37 PM
is there a way to just test my cluster to see if it is the cluster then before purchasing a new one? Everything works besides the speedometer. The cel came on before with code 17 and since i replaced the vss the cel has not come back but it is still not working on cluster. I figured since when i unplugged the vss and the cluster did not drop to 0 it has to be the cluster. Am i correct or could it be something else as well?
Old Jul 6, 2011 | 07:08 PM
hyperblu's Avatar
Put it in another ek civic... I doubt its the cluster.
Old Jul 6, 2011 | 07:25 PM
Deetz's Avatar
Crazy Honda Guy
Civic VTi
it's unique, and not common in north america
Old Jul 6, 2011 | 07:35 PM
hyperblu's Avatar
Originally Posted by Deetz
Civic VTi
We dont go by that km/h crap.
It would just annoy me.
Old Jul 6, 2011 | 07:49 PM
pliskin8's Avatar
jaja!! so true
Old Jul 6, 2011 | 08:44 PM
ev94eg's Avatar
try and see if the needle that goes through the mph is pushed to far in that happened to my cluster the gas stick was to far in and rubbing the surface of the cluster not letting it move
Old Jul 7, 2011 | 02:45 AM
I know that it is not stuck just because when the car is turned off it sits at 0 but as soon as I turn key to on position if flips up to the 20mph mark.
What makes people think its not the cluster? What else could it be if I tested the harness and all voltage is good. Is there a way to run a seperate speedometer? Like put one in a pod or something? Its really annoying not knowing speed and I drive highway a lot which means Im not really going slow most of the time.
Old Jul 7, 2011 | 07:36 AM
Deetz's Avatar
Crazy Honda Guy
Originally Posted by pliskin8
jaja!! so true
Next time you guys make comments like that, do some research, they were available in both formats
Old Jul 7, 2011 | 07:51 AM
cetcivic's Avatar
no one wants to hear the truth
Your only options would be: spoon or mugen ek clusters...pick 1
Old Jul 7, 2011 | 07:53 AM
kaiba's Avatar
Any year model Civic 96-00 and/or CRV 95-01.
Old Jul 7, 2011 | 09:06 AM
sw388's Avatar
Just ask a friend (with an EK or CRV 95-01) as kaiba stated to help you out and swap clusters to eliminate the cluster being an issue. If ur doin 45 mph in first gear ur **** may be *ucked!!!
Old Jul 7, 2011 | 01:27 PM
Is there a way to put a speedometer in a pod though and just run through that? I dont know anyone with civic cluster only teg cluster. I didnt know if there is a way to test the cluster besides placing into another car.
Old Jul 7, 2011 | 02:27 PM
Is it normal to disconnect the vss and the cluster still reads at the 20mph. I am clueless when it comes to electrical. I figured the code 17 meant the vss was bad so i replaced that. Anyone have any opinions on what to do? I did get a multimeter but i really dont know what to do. I did hold the middle pin on the harness and the right outter one and there was slight continuity. I dont know if that means there is a plice in the wiring or what. If so can I just follow the wires back to the ecu and run new wires directly to it?
Old Jul 7, 2011 | 02:43 PM
kaiba's Avatar
Yes, it is. There are 3 screw behind the speedometer. +, - and speed signal.
Old Jul 7, 2011 | 07:32 PM
ek4me96's Avatar
u can put an s2k cluster wit some modifications. looks very sexy
Old Jul 7, 2011 | 07:43 PM
anstitute's Avatar
yup, these are direct fit. even a caveman could swap them no problemo
teggy's require some electrical, s2000s look great too if you're good at that stuff
Old Jul 8, 2011 | 03:34 AM
what do i do with these screws? Would the speed signal cause my speedometer to stay at a constant speed no matter what? I also find it odd that I looked at my odometer and it has not changed. Would the odometer still change if the car speedo is not working?
Old Jul 8, 2011 | 04:31 AM
NOFX's Avatar
H-T White Ops
All '96-'00 Civic/Orthia/1.6EL clusters, plus the '97-'01 CRV cluster are plug and play.
Never heard of a 1995 or 1996 USDM CRV.
Old Jul 8, 2011 | 05:37 AM
kaiba's Avatar
Screw you, I just look it up on wiki.
steventrrr
Sep 26, 2010 08:34 PM
20-EM2-05
Honda Civic (2001 - 2005)
Aug 20, 2009 12:14 PM
areede
Aug 17, 2009 04:49 PM
