Bad fuel pressure reg. If pressure drop to zero when engine off
Old Jul 6, 2011 | 01:47 PM
eg:R's Avatar
Default Bad fuel pressure reg. If pressure drop to zero when engine off
I have a aem fuel pressure reg. When my car is turn off my fuel pressure drop stright to zero. Does this mean my reg. Is bad? I've seen on other cars and The pressure hold at their set pressure or drop a little while their engine is turn off. Let me know if this is a bad reg. If so I may need to purchase a rebuilt kit from aem. Thanks
Old Jul 6, 2011 | 03:29 PM
EsotericImage's Avatar
Retired Moderator
Default Re: Bad fuel pressure reg. If pressure drop to zero when engine off
when u turn the key off it goes to 0, or after a while it slowly goes to 0?
Old Jul 6, 2011 | 03:56 PM
non-VTEC's Avatar
check valve in the fuel pump could be bad...
Old Jul 6, 2011 | 06:25 PM
Gunmetal_B20_Hatch's Avatar
x2
Old Jul 6, 2011 | 06:32 PM
TotalKhaos24's Avatar
Where is the fuel gauge set up at before the regulator if so then i'll be checking the fuel pump it could be bleeding off. If after the regulator it can be the regulator or the pump. I've seen more pumps bad than regulators.
Old Jul 6, 2011 | 10:57 PM
eg:R's Avatar
It fall to zero right away when key off. The gauge is before the reg. If I remember right my b&m didn't do this.
Old Jul 6, 2011 | 11:42 PM
joppe's Avatar
my aem "oem style" regulator does same thing.
Old Jul 7, 2011 | 07:21 AM
StolenTeg's Avatar
All the shitty aem regulator does this, it a pain in the ***
Old Jul 7, 2011 | 08:42 AM
eg:R's Avatar
Is this normal for aem fpr or does it needs to be rebuilt? Anyone have one that hold pressure?
Old Jul 8, 2011 | 08:34 AM
welfarepc's Avatar
if the gauge holds the proper pressure while the car is running dont worry about it.
Old Jul 8, 2011 | 01:03 PM
turbohatch96y7's Avatar
It could be a a fuel leak chexk your injector seals and all the lines or put a vacume gauge on the line. Then test. Dont just swap parts fool
Old Jul 8, 2011 | 01:48 PM
DDTECH's Avatar
Old Jul 9, 2011 | 07:44 AM
RACEPAK's Avatar
i never had this on my aem fpr's
Old Jul 9, 2011 | 09:28 PM
pcguy760's Avatar
Hey I have a b&m gauge mounted right at the filter, on the line going to the fuel rail and it holds pressure for a few hours before dropping to zero ... I guess this is normal since I dont have any fuel leaks, etc.
EG-SIXV-TEC
Jun 23, 2012 02:58 PM
eg:R
Dec 31, 2011 11:42 AM
dunkd
Apr 6, 2006 07:47 PM
LXguy
Jul 3, 2002 10:50 AM
