staring problems on my crx
Old Jul 6, 2011 | 12:31 PM
jdm-chato's Avatar
Default staring problems on my crx
so i have a crx with a dohc zc.its not staring has power 2 the outside lights but when i turn over the key noting happens.the instrumental/dash lights dont turn on.its like i dont have power to the ignition switch. please someone help need it 4 work!!!
Old Jul 6, 2011 | 12:32 PM
ThatRicerDaniel's Avatar
Default Re: staring problems on my crx
Battery is dead. Lights will still turn on but not enough amps to crank the starter. pop the clutch.
Old Jul 6, 2011 | 12:37 PM
jdm-chato's Avatar
the battery is good it start it and i put my car back together and it didnt want to start its like a fuse or ignitions switch idk??? cause its getting power to the outside light but not power in inside when i turn over the key noting happens
Old Jul 6, 2011 | 03:24 PM
WanaBeFaster's Avatar
do the lights go off when you turn over the key? definitely sounds like a dead battery
Old Jul 6, 2011 | 03:44 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Cars don't stare unless they are Carrie... What do you mean you put the car back together?
Old Jul 6, 2011 | 03:57 PM
jdm-chato's Avatar
like i put it back together cause at first didn't want to start and i thought a fuse pop or something but the dash lights turn on but would not start but i switch the relay and it started but now it doesn't turn over i think its the relay am going to check it right now.
Old Jul 6, 2011 | 04:00 PM
jdm-chato's Avatar
when i turn over the key there no power in the car.just the outside lights turn on.i know it not the battery cause i took it 2 auto zoneand its good.
Old Jul 6, 2011 | 04:27 PM
jdm-chato's Avatar
when i turn over the key there no power in the car.just the outside lights turn on.i know it not the battery cause i took it 2 auto zone and its good.
Old Jul 6, 2011 | 04:36 PM
JustOneOrTwoPosts's Avatar
ecu grounds all connected? Starter wire connected? retrace what you did and work from there
Old Jul 6, 2011 | 04:50 PM
jdm-chato's Avatar
yeah all thats connected my buddy's are saying its the ignition switch?? do u think that?
Old Jul 6, 2011 | 07:01 PM
its a possibility, but i've yet to experience one of those failing on me so I can't say yes. Was this a problem on the car before? What have you done to it since before the problem?
MySelfAffliction
Mar 17, 2010 04:42 PM
squirrly
May 11, 2008 07:40 PM
HondaHemi
Dec 6, 2005 10:10 PM
