how to remove OEM fuel rail fitting ?
Old Jul 6, 2011 | 11:49 AM
Charlie Moua's Avatar
Default how to remove OEM fuel rail fitting ?
I wanted to use a male to male M12 x 1.25 to -6an fitting on the end of OEM fuel rail.
Q:
1) so how do you remove the stock fuel rail inlet fitting?
2) is it threaded or just pressed in with some sort of sealer from the factory?
* I tried heating it up with MAP gas and using VICE grip already.
* I went to Ace Hardware but they didn't have the right nut (was going to try to use 2 of them & try to turn if off)
Old Jul 6, 2011 | 12:03 PM
donut.'s Avatar
Default Re: how to remove OEM fuel rail fitting ?
I put mine in the vice and used vice grips. You can double nut it.
Old Jul 6, 2011 | 12:42 PM
what size nut did you use? I couldn't find any that worked.
What size is the inner pitch thread after you took off the brass inlet fitting?
Old Jul 7, 2011 | 06:52 AM
donut.'s Avatar
I used vice grips. You just gotta make sure you get those vice grips on there tight enough. I got it to the point to where I was barely able to lock the vice grips on. If you double nut it, I think it's a 14mm but it has to be short enough to fit 2 on there.
Pitch is 12mm x 1.25. So you need a 12mm x 1.25 to -6AN fitting with a crush washer.
Charlie Moua
Jul 8, 2011 08:48 AM
Charlie Moua
Jul 7, 2011 04:54 AM
turbo-crx
May 20, 2009 10:16 AM
turbo-crx
Dec 16, 2008 06:41 PM
