LS boost question
Old Jul 5, 2011 | 05:45 PM
rhartman0922's Avatar
Default LS boost question
I recently picked up a car from a buddy of mine, it is a fully built LS (eagle crank / rods, je pistons, sleeved / block guard, arp head studs, main studs and rod bolts...blah blah blah) with a turbonetics .63 trim turbo setup on 15 psi that supposedly was making 396whp. Im not sure if if feels like it is that high or not, but thats besides the point...on to my question...
When I got the car It had a b20 valve cover with a catch can setup, however the catch can was not right at all and not doing the job it should be, properly. It had two fittings welded into the front of the valve cover with what i believe was 10an lines running straight to the catch can, thats it, no vacuum or anything so it was pretty much just splashing oil into the catch can.
I bought another stock b20 valve cover and just put it on. My only concern is the stock PCV system for the amount of power i am making. I dont know if it will hold up, or if ill be okay for the time being.
Any help would be greatly appreciated. And yes I did search but I couldnt find any information pertaining exactly to what im doing.
Old Jul 5, 2011 | 06:04 PM
grumblemarc's Avatar
The Grumpiest
Default Re: LS boost question
Why did you post this here instead of the Forced Induction forum? They even have a thread going already that pertains to catchcan/breather setups.
b20forlife
May 21, 2012 09:58 AM
akandok
18
Sep 17, 2009 04:21 AM
Damills
Dec 29, 2008 01:17 PM
integra_dude
Apr 21, 2005 06:05 AM
