Knock Monitor
Im experiencing a bit of (from what I can hear) mid-load knock on my JRSC GSR. I am not currently running a Knock sensor but have the ability to do so IF anyone can confirm that the OEM knock sensor is a useful tuning tool.
I have attempted to use the OEM system in the past and it was detecting knock that was not there.
Ive seen homemade DET cans out of tubing and a pair of cheap ear protectors, but not sure on how accurate that method is.
Plugs look fine from what I can see
Thanks In Advance
Thanks In Advance
Those are all nice devices but for me a little expensive. Keep in mind this is a hobby not a profession.
Sitting at work thinking about this it should be "relatively" easy and cheap to build something myself.
From what I gather a knock sensor is not much more than a piezo electric microphone, and should be really easy to amplify this to an audible level through a simple portable speaker for an iPod or through an unused RCA input on your car stereo.
I'm sure I'm over simplifying this and not thinking it through completely.
http://www.summitracing.com/parts/MSD-8964/?rtype=10
its worth the investment, to build one yourself you probably would have to be able to calibrate it so that you wouldnt read phantom knock
We shall see.... Spending $270 on something I'll rarely use is pretty much out of the question. Seeing as the MSD is not likely geared toward a Honda engine anyhow.
Here another device for detecting knock http://www.phormula.co.uk/
plugged into Neptune too, egr lift input
adjusting it's engine bore dependent frequency parameter on the fly makes it's an all around tool.
