94 Integra RS clutch engage adjustment
Old Jul 5, 2011 | 09:24 AM
Rahes's Avatar
Default 94 Integra RS clutch engage adjustment
I was wondering if anyone could explain how to lower the engage point on my clutch, it engages when it's almost all the way out and its very annoying. So id like for it to engage a bit earlier. It's a 94 Integra RS with a 2000 GSR swap. Exedy stage 2 clutch.
Old Jul 5, 2011 | 10:37 AM
TOO MUCH TORQUE's Avatar
Default Re: 94 Integra RS clutch engage adjustment
hydraulic clutches cant be adjusted......
you should have gotten an exedy stage 1, that would definitely given you a lower engagement point.
maybe s2000 cmc...heard those lowers engagement points
Old Jul 5, 2011 | 12:48 PM
Rahes's Avatar
Well it's what was on the car when I bought it lol but thanks anyway!
Old Jul 5, 2011 | 02:19 PM
Jimmy's Avatar
Global Moderator
Buddy of mine is running an s2000 clutch master cylinder on his EK and it definitely changed the pedal feel.. I believe the rod is longer so when he purchased it, he also purchased a thick spacer as well.. That's about all I know about it.
Old Jul 5, 2011 | 06:34 PM
94EG8's Avatar
Seagull Management
You can adjust them, but not the way you want to, you set the disengagement height and freeplay and wherever the clutch engages is where it's meant to engage. If you screw around with it beyond that it'll either slip or remain partially engaged depending on which way you adjust it.
Old Jul 5, 2011 | 08:06 PM
Rahes's Avatar
Gotcha! I guess I'll just get used to it than xD
patrick4588
May 9, 2008 09:38 AM
dagle
Honda S2000
Jan 2, 2008 12:43 PM
redsikiller
Dec 2, 2005 08:58 AM
integraracer92
Nov 1, 2004 07:16 PM
Ek9Max
Jun 8, 2004 11:34 AM
