compressor blade rubbing against housing
Old Jul 4, 2011 | 10:09 PM
boostedBLUfg2's Avatar
Default compressor blade rubbing against housing
here's the thing.. there is almost zero shaftplay on the turbo. no more than what's normal of a turbo with a few k miles on it. this is a garrett turbo, mind you.
before i purchased it, i had asked the seller to send me pics with the housings off so that i could see the blades. is there any possibility that the housing was put on cockeyed and is now causing the blade to rub against it? i would just take it off and check for myself, but i'm worried about damaging the turbo further.
the turbo was purchased used from a very respectable shop, and they are insisting there was nothing wrong with the turbo when it was pulled from their car. the turbo has under 5k miles on it, and like I said, very minor shaft play, so i'm at a loss for why the blade is touching the housing.
thanks
Old Jul 5, 2011 | 04:47 AM
Mr. Anderson's Avatar
From: A gas station with 87, 89, 91, 92, 93 octane, FL
Default Re: compressor blade rubbing against housing
The housings are going to need to be taken off either way to check for additional damage you may not see. When the journal bearing started to go out on my Turbonetics, there was a lot of wear under the turbine wheel in addition to the comp. blades rubbing from the horizontal shaft play. Unlikely that the comp. housing was cockeyed. See if the shop is willing to work with you on new parts and a balance.
Old Jul 5, 2011 | 08:30 PM
Looks like I might as well just trash this entire turbo then, sounds like it needs a full rebuild.
Old Jul 5, 2011 | 09:20 PM
civickiller's Avatar
my friends turbo did this, took off the housing and gave it a light sanding and now 10k later and still no problems
Old Jul 5, 2011 | 10:00 PM
Interesting.. I had the same thoughts earlier, but I wasn't sure if it was legit to sand out the comp. housing or not.
EJ8 944
Jun 16, 2008 06:47 AM
AaronJ
Jan 4, 2007 02:27 PM
kell211
Mar 4, 2004 02:16 PM
seanjohn81
Jul 8, 2003 01:00 PM
