Fuel Rail Spacers
Old Jul 4, 2011 | 03:43 PM
geek504's Avatar
Icon3 Fuel Rail Spacers
~short story:
Does anybody knows the dimensions (thickness, diameter, etc.) of the stock B18B1 fuel rail spacers?
~long story:
Engine misfired cylinder 3 and 4. So I decided to clean the fuel injectors.Noticed my new-used 1997 LS was missing 2 fuel rail spacers. Took off the fuel rail, ...started to rain..., third one fell-off and is stuck between the thermostat housing and intake manifold.
PLAN:
a) Tried the magnet, but it's made of plastic.................fail
b) small point, long extended flat screw driver...............fail
c) clothes hanger, modified with a hook........................fail
d) thin kebab wooden stake with duck tape in the end.....fail
......so I'm just planning to leave it there and custom make a spacer.
Old Jul 4, 2011 | 04:21 PM
andrewxxcarlson's Avatar
Default Re: Fuel Rail Spacers
Take off your intake manifold duh :]
Old Jul 4, 2011 | 04:26 PM
geek504's Avatar
LOL.
I'll consider it as plan (g)
Tried Google, Acura Dealership online reference, Ebay, Amazon, and still can't get the numbers!
At least I found out the studs were: M6 x 22mm w/ 1.0 threading..........
Old Jul 5, 2011 | 09:19 AM
geek504's Avatar
Originally Posted by geek504
~short story:
I tried plan (d) again with modifications.
Here is what I have...
8mm thick, 20mm diameter, 7mm inside
Old Jul 5, 2011 | 10:07 AM
sc34dc4's Avatar
The only part you need to worry about is the thickness. Outside doesn't matter and inside either as long as it's big enough to go over the stud. I just stacked washers for my fuel rail spacers.
Old Jul 5, 2011 | 11:19 AM
geek504's Avatar
Originally Posted by sc34dc4
The only part you need to worry about is the thickness....just stacked washers for my fuel rail spacers.
A million thanks!
I went to Home Depot, bought the (14) 1/4 cut washers [$0.11/each], stacked it on two sides and left the middle deleted.... so far no leaks!!!
Again thanks, you are a genius! ^_^
recaroem2
26
Apr 8, 2009 09:04 PM
Redemption
Free Stuff
Feb 13, 2009 11:47 AM
euclid
Jul 20, 2003 10:39 AM
Buckshot
Nov 13, 2002 10:35 PM
