WTT 95 integra
Old Jul 4, 2011 | 08:33 AM
atleast-3's Avatar
Default WTT 95 integra
I want to TRADE this car. Looking for honda/acura/nissan/toyota/subaru, or maybe an suv. Please email info and pics of your vehicle.
Heres the details. Car would need tow. Has been garage kept under a car cover, no rain, no snow.
95 integra ls, mileage unknown, I got it as a shell with no cluster.
Chassis Pros:
Semi wire tuck
abs delete, swapped to Rs lines booster master cylinder
srs delete, all wiring gone, type r passenger air bag tray
sparco harness
a/c delete, lines everything, type r heater tube installed under dash
new ss brake lines, cross drilled rotors and pads
nuespeed race springs, koni red shocks, ingalls camber kit
del sol 14" si wheels
amber bulbs in cluster
type r amber cd player
3 gauge din pod, temp, pressure, volt, auto meter all new
rear wiper delete
black interior nice
Chassis cons:
No front bumper
needs alignment
needs tires
brakes need bleed
holes in trunk for spoiler
front fenders black
need hood pins installed, have them, no latch
no speakers inside
wire rad fan to switch, or replace relays
carpet stained
Engine Pros:
95 b18b ls motor and trans
act stage 1 clutch light weight flywheel
new starter
new clutch slave, and ss line
new fuel filter and stainless line
alum rad w/ dual slim fans
ctr n1 crank pulley
ctr pistons ls rods
crower all motor cams and valve springs
aem cam gears
high flow fuel rail b&m fpr w/ gauge
skunk2 intake mani
hondata intake mani gasket
msd blaster coil and cap, new
ngk plugs and wires new
type r throttle body and intake arm
comptech ice box and ram air horn
oddy 680 battery and summit holder
new honda trans fuild, and royal purple motor oils
p75 ecu with hondata s200 installed
avid shift linkage and prothane bushings, new
skunk2 short shifter new
weapon r overflow tank
engine runs good, no smoke, no funny stuff
Engine Cons:
No exhaust, no headers
battery needs recharged
couple hoses from tb to im need hooked up
unknown mileage and inturnals done by previous owner.
No programs in s200. fpr and cam gears set to stock settings. so can be tuned for more power, or left as is.
Old Jul 4, 2011 | 01:42 PM
Gambitlp's Avatar
Default Re: WTT 95 integra
Pm be your number very interested in buying? Let me know if your willing to sell?
Old Jul 5, 2011 | 09:55 AM
atleast-3's Avatar
bump
Old Jul 8, 2011 | 09:28 PM
atleast-3's Avatar
Would be interested in trading for a 96-00 civic ex 5spd, bump
atleast-3
Jul 27, 2010 08:03 AM
tradesalot
Oct 8, 2008 03:48 PM
FastKTJ
Apr 26, 2008 10:45 AM
Chiclets
Nov 5, 2004 09:26 PM
