LA 1994 Turbo Ls-Vtec Civic HB
I have 1994 Ls-Vtec Honda Civic Hatchback for sale. I'm asking $6,000-OBO. The car runs good and has a fully built motor and is running on a Phearable Base Tune, currently i am running the DSM injectors in here with the resistor box but i do have the Precision 1000cc injectors that will go with the car. The car does have some dents and dings.
The car sometimes wont stay in 3rd gear but doesn't grind or make any noises going into the gear or any other gear for that matter, should be an easy and inexpensive fix.
The motor is not sleeved and the head was hand ported by a friend that does head work, the head has the stock B16 cams in it.
I drive the car usually every other day around town just to keep it from sitting up and haven't had any issues with it at all. The car doesnt have much interior and it also has an Integra dash and gauge cluster in it so the door panels had to be notch to make it fit the dash right when you close the door.
The motor only has about 8,000miles on it, im not exactly sure the mileage on the tranny nor the chassis. The car sometimes does smoke only when i start it up but not everytime, more like 1 out of 5 times i start it and its a very small amount and doesnt last long. Maybe a sec or two, but i have a new set of Ferrera valve seals i will throw in with the car.
The roof of the car has damage from previous owner not locking the hood down and the hood smashed the windshield and roof. I replaced the windshield but the roof still needs some work.
Only reason im getting rid of the car is cause i want a bike and im kinda falling out of the car scene. If you have any other questions please contact me and i will get back to as soon as i can.
Mods list is as follows:
chasebay engine harness
socketed p28
phearable basemap
neukin exhaust manifold
neukin downpipe
edelbrock intak manifold
aem fuel rail with pressure gauge
walbro fuel pump
hondata heat shield intake manifold gasket
precision sc61 turbo
tial wastegate
tial knockoff bov
lsvtec
todo valve train
golden eagle lsvtec kit
cp pistons
eagle rods
oem water pump
oem gsr oil pump
oem headgasket
competition stage 5 clutch
precision 1000cc injectors
t1 3 bar map
precision big intercooler
omni power rear control arms and front camber kit
Nippon wheels
carbon fiber duckbill
ground control coilovers
rear wheel disc conversion
front drilled rotors
fast turbo oil lines
sumitomo htr tires
ngk plug wires
ngk racing spark plugs
mugen upper rear sway bar
skunk 2 rear strut bar
socketed p28
phearable basemap
neukin downpipe
walbro fuel pump
tial wastegate
tial knockoff bov
lsvtec
todo valve train
cp pistons
eagle rods
oem water pump
oem gsr oil pump
oem headgasket
t1 3 bar map
Nippon wheels
sumitomo htr tires
ngk plug wires
Last edited by Swervin95EX; Jul 3, 2011 at 11:58 PM. Reason: additional information
slammedlsteg
Nov 1, 2006 06:12 AM
jsull.
Mar 9, 2005 09:29 PM
