Vitara build question
Old Jul 3, 2011 | 10:41 PM
n/aeghatch56's Avatar
Default Vitara build question
Hey guys im planning on doing a vitara build, but i was wondering what else would i need to do to my car to do a proper build. thanks!
Old Jul 3, 2011 | 10:48 PM
Corksil's Avatar
Default Re: Vitara build question
a vitara? you mean a suzuki?
GTFO or you will be EXPUNGED!
or explain what a 'vitara' is in honda terms - cuz i'm out of the loop and id love to know
Old Jul 3, 2011 | 11:44 PM
i read about this build online some where its called a "vitara build" its for a d16z6, i read that you use vitara pistons ( for a civic, look um up on ebay) and eagle rods for the bottom end and it can handle like 20 lbs of boost. that's really all i know about it. I wanted to see anyone has done this build on this forum or any better ideas for a turbo d16z6 build
Old Jul 4, 2011 | 12:33 AM
Cresendo's Avatar
Vitara r low compression pistons that u can use in d series engines great for a cheap turbo build
Old Jul 4, 2011 | 01:56 AM
owneyboy's Avatar
you can start by searching vitara build on google and gather ideas of what you need and start from there.. why bother wasting post having people reply when you can do the work for your self. look up brand name parts and things people have done that were known to work. dont reinvent the wheel if you dont need to.
75mm vitara 7.5 1 pistons with the crappy eagle rods or go with custom legnth I-beamst that raise compression
Old Jul 4, 2011 | 03:14 AM
Wrona's Avatar
wow just wow
http://www.youtube.com/results?searc...ild+civic&aq=f
Old Jul 4, 2011 | 03:21 AM
grumblemarc's Avatar
The Grumpiest
Go look in the forced induction forum.
Old Jul 4, 2011 | 09:14 AM
thanks guys!
Old Jul 4, 2011 | 09:22 AM
xide_12's Avatar
Iv done a d16z6 vitara build and Im pretty happy with it so far. Though I would suggest getting the custom length rods to keep the stock compression ratio unless you plan to run a lot of boost. I have the golden eagle rods and the compression ratio is something like 7.4:1.
other things you definitely should get:
-new connecting rods
-new main journal bearings
-new piston rings
-fresh hone on the block
-arp head bolts and rod bolts
-new head gasket and timing belt
-and obviously a whole turbo set up
also if you get the golden eagle rods you will have to grind down the bottom of the cylinder wall and part of the main cap
Old Jul 4, 2011 | 09:27 AM
well see i guesss i should of been more specific but do you have anything done to the head? like cam valve train etc
Old Jul 4, 2011 | 09:35 AM
xide_12's Avatar
nah not yet, my head is completely stock. I was going to get a zex 59300 cam but I need to save my money
Old Jul 4, 2011 | 09:44 AM
okay
Old Jul 4, 2011 | 09:48 AM
The Grumpiest
Stock heads are good to about 300HP.
Old Jul 4, 2011 | 10:35 AM
that is good to know
Old Jul 4, 2011 | 12:25 PM
owneyboy's Avatar
where do you get your info from? for the topic you can always upgrade your engine but its all up to what you plan to use it for. its not at all necessary until a certain horsepower point.
Old Jul 4, 2011 | 12:37 PM
The Grumpiest
Where? Here on H-T and other places. I researched my little meager build for nearly a year and that was the general consensus.
Here's one.
http://www.d-series.org/forums/force...urbo-head.html
You have info to the contrary?
Old Jul 4, 2011 | 01:13 PM
owneyboy's Avatar
i do. but its whatever not my build. it wont hurt to upgrade cams and valve springs and proper port job
Old Jul 4, 2011 | 05:17 PM
apexi_rsx's Avatar
i dont understand why people do the vitara builds anymore the piston and eagle kit is just about the same as a wiseco/eagle kit.... vitara's yield very very low compression..as well as they're cheaply made and are known to have piston slap.
Old Jul 4, 2011 | 05:21 PM
apexi_rsx's Avatar
grumblemarc is correct a stock z6 head can make up to 300hp before starting to choke it out. one thing about hondas they do have good head flow compared to many other auto makers. also stock ignition is good for 300hp as well. a cam would help achieve the goal easier with less boost. if your going to run a big cam u should have your head ported to get the max output of the cam.
Old Jul 5, 2011 | 07:03 AM
Okay, What would be the best bang for buck type thing to go here for piston/rod combo than, i wanna run around 16 lbs of boost as a daily
Old Jul 5, 2011 | 07:21 AM
Red_Army's Avatar
you could almost do that on a stock engine.
search in the FI forum since this is their cup of tea.
Old Jul 5, 2011 | 07:47 AM
The Grumpiest
16PSI on what? Do some research please. When setting goals PSI really has nothing to do with anything.
Old Jul 5, 2011 | 08:16 AM
T3/t4 Turbo on a built block.
Old Jul 5, 2011 | 08:22 AM
The Grumpiest
Goals please. Horsepower?
Let's not have to pull teeth for every little detail.
If you tried to post these vague questions in the FI forums you probably would get it locked.
Old Jul 5, 2011 | 09:37 AM
apexi_rsx's Avatar
i paid 725 shipped for my wiseco/eagle combo. 10 psi on a gt28r is different then running 10psi on a gt30r. the gt30 flows more and will make more power. you could run 16psi on a greddy t25 turbo and make a little over 200hp on a stock block. psi is irrelevant you need to have the car TUNED to your power goal and not just turn the boost up to 16psi without a tune even a built block will fail if not tuned correctly. t3/t4 id imagine ur buying a cheap *** ebay turbo that wont last long. u may wanna research more and make sure u run a oil restrictor.
