Pata's civic parts FS (96-00)n(92-95)
here's some parts for sale for ek and eg.
Located in East Los Angeles
PM or text 213-494-78o4
pick them up or I can ship for additional cost.
will update and bump if and when I get more stuff in...
fuse box off ek $10
cluster cover off ek - $5
civic obd1 fuel injector plugs - $5
civic 92-00 d-series used clutch w/ pressure plate - $20
civic 92-00 flywheel - $25
special item:
fender screws w/ washers - 25 for $15
replaces all of your 10mm bolts under the hood
socket cap screws - $15
I have a couple extra sets I didn't end up using.
kit will include:
3 for dizzy
2 for fuel pressure regulator
2 for throttle cable bracket
2 for cam cap (dizzy end)
2 for top housing of radiator hose
6 for vtec soleniod (if applicable)
2 for power steering top hose (if applicable)
2 for brake prop valve
(or whatever 10mm bolt you want to replace, Pm me, I might have it)
fuse box off ek $10
special item:
kit will include:
3 for dizzy
Mobil one 5w-30 full synthetic motor oil (new) - 4qts - $20
red oval light w/ rubber grommet comes with pig tail wiring - $10
sample pic
civic obd1 fuel injectors - $15
used . oem
civic obd1 fuel injector clips - $5
Civic obd2 D16y7 fuel injectors - $20
Used . Oem
Civic obd2 fuel injector clips - $5
D16y7 / D16y8 A/C Comp. Bracket - $30
D16y7 - D16y8 - 96-00 Civic engine post mount - $25
D16z6 - 92-95 civic A/C Comp. Bracket - $25
A/C pulley included
D15b7 complete intake manifold - $25
no tb.
will have pix
D15b7 head - $30
came off running car. Block spun a rod
will have pix
civic D16z6 complete engine harness - $60
Nice n wrapped with new black electrical tape
must be 18yrs to buy spray paint
Krylon black spray paint - new - $3 picked up
can ship but don't know how much
Krylon primer spray paint - new - $3 picked up
WD40 - new tall can - $5 picked up
Gasket maker - new pack - $4 picked up
can ship for $4 more
Thread will be updated as I go.
Thanx
sample pic
used . oem
Used . Oem
A/C pulley included
no tb.
will have pix
D15b7 head - $30
will have pix
Thanx
Bbbbbbbbbbb.......uuu..........uuu....mmm......... .......mmm.....ppppppppp
bbbbbbbbbbbb.....uuu..........uuu....mmmm......... ...mmmm.....ppppppppppp
bb..............bbb.....uuu..........uuu....mmmmm. .......mmmmm.....pppp......pppp
bb.............bb........uuu..........uuu....mm... Mmm..mmm...mm.....pppp......ppp
bbbbbbbbbb.........uuu..........uuu....mm....mmmmm m....mm.....ppppppppp
bb.............bb........uuu..........uuu....mm... ...mmmm......mm......ppp
bb.............bbb......uuuu......uuuu....mm...... ...............mm......ppp
bbbbbbbbbbbb......uuuuuuuuuu.....mm............... ......mm......ppp
bbbbbbbbbbb.........uuuuuuuuu....mmmm............. ...mmmm...ppppp
