Question about swap reliability
Old Jul 3, 2011 | 03:03 PM
Beslan's Avatar
Default Question about swap reliability
Hello to all fans of engines !I have a question for all of you what is the most powerful motor is suitable for HONDA CIVIC 4WD sedan 1988-1991 Guys help ! I do not know who else to ask,how do You Help the motor brothers !
Old Jul 3, 2011 | 06:31 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Question about swap reliability
In Soviet Russia, car swaps you!
OBD-0 = D16A6 (or D15B)
OBD-1 = D16Z6 (or D15B)
OBD-2 = D16Y8 (converted to OBD-1)
Old Jul 3, 2011 | 08:34 PM
Beslan's Avatar
Brother thanks but the Soviet Union has sunk into history,and the machines we go straight from Japan in Vladivostok ! Thank you brother for information,here is another question which I will recommend the engine to deliver the most powerful,so then I could make it even more powerful,help brothers! As you name one?
Old Jul 3, 2011 | 08:38 PM
Beslan's Avatar
Guys engine H2B fit?
Old Jul 3, 2011 | 09:04 PM
Beslan's Avatar
I need the most powerful serial 16v engine for the civic 88-91. Friends I have a lot I don't know I ask for help from you at all.
Old Jul 3, 2011 | 09:17 PM
Beslan's Avatar
DOHC VTEC 16v ?
Old Jul 4, 2011 | 04:05 AM
1990edsedan's Avatar
For bolt in dear comrade, you can go dohc ZC. That will bolt in and give you 130hp. Prosit!
Old Jul 4, 2011 | 04:07 AM
DO IT ON ALL FOURS
The Soviet thing was just what I hear my kid saying... Some type of American joke I guess?
Well the list I gave you isn't the most powerful Honda engine... It was for the car you have. You say you have an AWD - well the only true way to get "the more/most" powerful motor would be to convert to a B20/CR-V setup. Tons of work in hackig the vehicle is involved. The AWD system is something (if you want to retain it) that is not easy to work around. Essentially you are stuck with a D-series but it also has to had a spot for the intermediate shaft on the block if I recall correctly. So most of the motors I listed won't actualy easily work as a direct bolt-in but more towards the most powerful D-series engines for their respective OBD.
Old Jul 4, 2011 | 04:09 AM
DO IT ON ALL FOURS
Ah yes, my fault, I somewhat was assuming SOHC as a requirement - I should read better.
Old Jul 4, 2011 | 04:17 AM
But you do bring up a very valid point. Does the OP still want to maintain the AWD system or go FWD? Then the only logical step would be a Mini Me using his stock bottom end if maintaining AWD.
Old Jul 5, 2011 | 09:28 AM
Beslan's Avatar
What can you say about b18c engine ?
Old Jul 5, 2011 | 09:31 AM
Beslan's Avatar
One tell me what is the most large throttle valves put in place with the largest receiver?
Old Jul 5, 2011 | 09:33 AM
Beslan's Avatar
As said honda is a whole philosophy, and science in one engine!
Old Dec 29, 2011 | 11:59 PM
Beslan's Avatar
Guys who will tell what most powerful engine v-tech type-r b20b it is possible to put without problems and body completion under engine fastenings on model CIVIC 4WD sedan 1988-1991 or there are even more powerfully engines prompt to all I will be very grateful?
Old Dec 30, 2011 | 12:09 AM
Beslan's Avatar
Guys what most and the powerful turbine will go on the standard engine b20b??? Who knows help?
Guys not how to find for the atmospheric engine final system it is desirable the biggest diameter which only it can not is possible to put help with the information please
Old Dec 30, 2011 | 12:18 AM
stackedhouse's Avatar
If I were you I would just turbo your stock motor and retain the awd system
Old Dec 30, 2011 | 12:25 AM
NOFX's Avatar
H-T White Ops
Hello, Beslan. Welcome to Honda-Tech.
Many different engines fit in the 1988-1991 Honda Civic.
Since you have AWD it would be easiest to keep a D-series engine. If you change to a different series engine then the transmission will need to be changed as well. If you want to keep AWD you want to keep D-series transmission.
Yes, people have swapped in B-series, H-series, K-series and even J-series into 1988-1991 Civics/CRXes.
Other people have posted some good suggestions for engines.
Old Dec 30, 2011 | 04:38 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Beslan, post in Russian, i'll translate.
BTW Tolyatti is a great city, have family there still
Old Dec 30, 2011 | 04:40 PM
the most concise advise. my opinion would be to simply boost a civic SI engine (that would be the ZC single cam from the boat)
Old Dec 30, 2011 | 07:34 PM
NOFX's Avatar
H-T White Ops
Thanks!
Also thanks for the compliment on my post. I tried to type simply so it might be easier to understand too.
Old Apr 23, 2012 | 12:23 PM
Beslan's Avatar
The brothers tell me which sports items are the cheapest and reliable of all the Japanese brands who can help me be grateful, just here in Russia with great prices wrap want to ask all of you brothers?? Help!
Old Apr 23, 2012 | 12:26 PM
Beslan's Avatar
Which brand is the cheapest of all the market tuning and racing for Honda??
Old Apr 23, 2012 | 01:11 PM
Jockone's Avatar
To keep your AWD system I think the best choice of engine would be a DOHC ZC as has been said before it will bolt right up to everything in your car and give you more power and is a good engine to boost if you want even more power from it.
Welcome to Honda tech and good luck with the car.
Old Apr 24, 2012 | 11:27 AM
Beslan's Avatar
what engine fits in the 1991-2000 series??
I need a large amount to build turbo engine monster
Old Apr 24, 2012 | 12:06 PM
Beslan's Avatar
The brothers what you have in the United States is the best brand to build a monster turbo to travel on every day
greddy hks apex mugen who are not hard to give a reference to the prices for parts that cost less! I would be grateful in advance
