Confused as a MOFO... need help with the swap.. someone plz....
same coil-distributor issue......... the coil=distributor that came with the accord is a five pin and five wire socket and kinda oval.... i have an lx accord. the socket off that is like round and has three wires. so i cant splice the h22 one cause i ll be missiong two wires??/ ok so i am using the EX harness.. well i cant use an EX coil-distributor cause *yeah its the only thing that plugs in * but it won fit on the h22 block right.. i can drill holes into the block?? how do you guys solve this?
koreachangsu
Aug 6, 2006 12:01 PM
ricekiller1
Mar 26, 2004 03:23 AM
