Engine Build! Final Hone! Align Bore! Copper ''O'' Ring Groove!
G.E. Welcomes walk in customers for complete short block servive of any kind.
1. Incerts
2. Step Deck
3. Final Hone
4. Align Bore
5. Hot Tank & Bead Blast
6. Custom Notch girdle or block for custom rods
7. Balance Rods, Pistons, Crank
8. Check piston wrist pin fit
9. Micro Polish Crank
10. Custom build Turbo or NA
11. Girdle install W/ Align bore
12. Ring gap
13. Sleeving
14. Clean up hone
15. Pressure test block
16. Piston, Rod & Crank sales. Please call first to check stock
''Do not hesitate to call or ask for any help needed with your project''
Contact us any time via pm, e-mail or land line
sales@goldeneaglemfg.com
Bob 909-592-4311 x 14
Jon 909-592-4311 x 13
Shop hours; 8am to 5pm Monday-Thursday / Friday 8am to 2:30pm Closed Sat & Sun
1. Incerts
2. Step Deck
3. Final Hone
4. Align Bore
12. Ring gap
13. Sleeving
14. Clean up hone
1. Incerts
2. Step Deck
3. Final Hone
4. Align Bore
12. Ring gap
13. Sleeving
14. Clean up hone
1. Incerts
2. Step Deck
3. Final Hone
4. Align Bore
12. Ring gap
13. Sleeving
14. Clean up hone
G.E. Welcomes walk in customers for complete short block service of any kind.
1. Incerts
2. Step Deck
3. Final Hone
4. Align Bore
12. Ring gap
13. Sleeving
14. Clean up hone
Cali Life !
1. Incerts
2. Step Deck
3. Final Hone
4. Align Bore
12. Ring gap
13. Sleeving
14. Clean up hone
Cali Life !
GOLDEN EAGLE MFG.
**ACCESSORY KIT**
DECALS - T SHIRT - LICENSE PLATE FRAME - KEY CHAIN - LANYARD
$ 29.99 SHIPPED US 48 STATES ONLY REGULAR GROUND
**ACCESSORY KIT**
i have a d16z6 engine that i have taken apart. It had a bad crank and bent rod. I just purchased a new crank, rod, and have a higher comp set of pistons i purchased. I'm not in the process of putting this back together. What services do you provide/suggest i do? Can you give me a rough estimate on pricing. thanks.
1. Incerts
2. Step Deck
3. Final Hone
4. Align Bore
12. Ring gap
13. Sleeving
14. Clean up hone
1. Incerts
2. Step Deck
3. Final Hone
4. Align Bore
12. Ring gap
13. Sleeving
14. Clean up hone
Build ''N'' Boost the Limit!
Crate Engines custom built Shipped World Wide
Boost up to 60 psi
Sleeves will not sink or crack
Ductile Iron sleeves
Boost up to 60 psi
