Zc to d16z6 swap
You need a P28 ECU or a vtec converted P06 if you want to run OBD1. This would require the jumper harness for the ECU and the distributor converter plugs. 4 wire O2 also. Staying OBD0 requires an RPM activated switch hooked up to engage vtec. MSD made something like that.
jdm.swift
Oct 24, 2010 10:27 AM
hondacrxjdmsi
Feb 20, 2006 12:31 PM
