new kyb struts, h&r 51852 lower kit, now rides like shit, and squeaks please help
Old Jul 1, 2011 | 11:32 PM
95halx's Avatar
Default new kyb struts, h&r 51852 lower kit, now rides like ****, and squeaks please help
I wanted to lower the 95 accord. with the h and r 51852 kit supposed to be 1.75 front and 1.5 rear drop. Installed now sounds almost like its on the bump stops? I cut the front bump stops in half. A little better now. But still squeak sounds when going over bumps slowly.. I measured another accord today and the front of mine was 3.25 inches lower. Why? Anybody. kyb struts. I think they were 341497 and 341498
Please help any ideas of what the problem is. I seems to be very bouncy. I had a 93 civic with 19 inch wheels and a neuspeed race drop that rode better. I still have the stocks on the accord.
Old Jul 1, 2011 | 11:42 PM
95halx's Avatar
Default Re: new kyb struts, h&r 51852 lower kit, now rides like ****, and squeaks please help
Could the squeak be something else. Control arm bushings, etc?
Old Jul 2, 2011 | 10:26 PM
mdeserteagle50's Avatar
This... Also, when you swapped the spring/strut combo, was it delivered to you 1.assembled or 2.did you have to put the strut/spring combo together yourself? If it was option 2, did you buy new strut bearings/collars? WHat I mean is part 12 and 10 in the diagram below.. The reason I asked is a lot of times when spring/strut combos are replaced(regardless of stock or aftermarket specifications) people don't want to spend the extra money to get the strut bearings/collars replaced and quite often get "squeeks" and/or a "jounce/bouncing/bottoming out" feel from the suspension when hitting rough ares in the road or going over speed bumps.
Old Jul 2, 2011 | 10:58 PM
95halx's Avatar
I will try to replace that upper spring seat, thanks.
Old Jul 4, 2011 | 06:19 AM
HondaTuner4267's Avatar
Also keep in mind that lowering your car will put more stress on all of those old balljoints and bushings. My UCA's squeaked when I first did my drop on H&R Sport springs and KYB AGX's until I replaced them.
Old Jul 5, 2011 | 09:55 PM
95halx's Avatar
Ok the rear has stopped. Im gunna try to replace the spring seat on the top of the front spring.
Thank you
Uca's ? upper control arms?
Old Jul 6, 2011 | 07:06 PM
Yup...
wannabemechanic
Jul 8, 2013 12:47 PM
TwoKSiR
May 25, 2008 02:01 PM
rillboss
Dec 6, 2004 10:53 AM
Jdmglenn
Nov 13, 2004 08:56 AM
akaEsCo01
Jul 28, 2003 10:33 PM
