Suspension & Brakes Theory, alignment, spring rates....
94 ex coupe...gsr f/r brakes...which proportioning valve?
Old Jul 1, 2011 | 09:31 PM
Y2K Si FBP's Avatar
Default 94 ex coupe...gsr f/r brakes...which proportioning valve?
got a 94 ex coupe...originally rear drum...non abs...
have front and rear gsr brake setup....which proportioning valve is needed?
how will the setup work if it's not changed?
thanks in advance...
Old Jul 2, 2011 | 08:01 PM
abs0Lut's Avatar
Default Re: 94 ex coupe...gsr f/r brakes...which proportioning valve?
You won't feel much of a difference between your old drums and the new rear disks with the current prop valve, you need a prop valve from an EG Si to fully utilize those rear disks.
Old Jul 4, 2011 | 09:30 PM
drzxc1usive's Avatar
u realize that have the same size front brakes as a gsr... most of the breaking is in the front
88crxvtec
Mar 2, 2014 04:34 AM
Y2K Si FBP
Suspension & Brakes
Jul 1, 2011 09:30 PM
Xscort
Jan 24, 2009 09:19 PM
92ehatch
Dec 16, 2006 08:08 AM
