Over heating when I have any thermostat in the car...
Old Jul 1, 2011 | 08:50 PM
xwhitchx's Avatar
Default Over heating when I have any thermostat in the car...
Well I just put a new jdm engine in to my car last week and i have been over heating every time I put a thermostat in to the car. and with out it in the car it still runs a lil hot, at about 1/4 of the way.
So when the thermostat is in the car ( its an brand new thermostat and i have tryed other new ones also) the car will drive for about 2 block and got to over the H. But when I get out of the car and feel the radiator, the top is super hot and the bottom is cold, and if i feel the bottom hose it is cold and fells like there is no water in it, its all soft.
I have a ebay aluminum radiator btw.
As for the engine, It have been cleaned inside and out and have all new seals and gaskets every where and It has a new water pump.
So anyone know what this could be?
Here is a picture of my engine bay for all you people that like pictures =P
Old Jul 1, 2011 | 09:13 PM
apexi_rsx's Avatar
Default Re: Over heating when I have any thermostat in the car...
you replaced the head gasket? have you checked to see if your fan is coming on? if u haven't checked. turn the key in the ON position not started and take the plug off the fan switch sensor on the thermostat housing and jump the connector with a piece of wire or paperclip. if it doesn't come on u have a problem with the wiring to the fan,fuse, or fan switch is bad.
Old Jul 1, 2011 | 09:15 PM
xwhitchx's Avatar
Head gasket is new and there is no oil in the coolent and no coolent in the oil. as for the fan I have checked that and it all works just fine.
Old Jul 1, 2011 | 09:34 PM
salbaje's Avatar
have you bled the line yet??
Old Jul 1, 2011 | 09:41 PM
EsotericImage's Avatar
Retired Moderator
do you know how to bleed the cooling system correctly?
Old Jul 1, 2011 | 10:37 PM
virgineg6's Avatar
Is that the same radiator you had with the other engine?
Old Jul 2, 2011 | 12:08 AM
xwhitchx's Avatar
Yes I know how to bleed it. And. I did. And its same radiator
Old Jul 2, 2011 | 02:51 AM
HondaPartsHero's Avatar
Technical Hero
Are you saying that you've tested the fan and it works or the fan comes on normally on cycles as it should?
http://techauto.awardspace.com/overheating.html#6
Old Jul 2, 2011 | 10:22 AM
motegicivic's Avatar
When you say jump it, do you mean the plug itself? or the piece that is still plugged into the thermo housing?
Old Jul 2, 2011 | 11:44 PM
xwhitchx's Avatar
My Fan is working just fine when theres no thermostat in the car.
Old Jul 2, 2011 | 11:57 PM
ThA IntegrA HI's Avatar
you sure you put the thermostat the right way? is the bottom hose clogged
Old Jul 4, 2011 | 09:50 AM
xwhitchx's Avatar
Yes I did. The pin is up and its going the right way. I didn't know that there was a way to do this wrong.
And no the bottom hose is not clogged.
Old Jul 4, 2011 | 11:21 AM
Slopoke's Avatar
How many thermostats have you tried?
Its not uncommon to run into a faulty thermostat, right out of the box.
Old Jul 4, 2011 | 03:01 PM
LoLoCivic's Avatar
do you have an CEL?
Old Jul 4, 2011 | 04:18 PM
instructor74's Avatar
either you have a bad tstat, its in wrong or you have a large air pocket. If the car doesnt over heat with it out then you know the cooling system is working. So the only varriable is the Tstat not openning because you have a large air pocket behind it, or it is defective out of the box
Old Jul 4, 2011 | 05:05 PM
apexi_rsx's Avatar
you unplug the plug from the sensor and jump the plug with a paper clip or piece of wire... not the sensor
Old Jul 4, 2011 | 06:59 PM
CivicBlacksheep's Avatar
10 Year Member
Clog in radiator...it goes the same with a heater core..if the inlet is hot, but outlet is cold, the heater core is internally clogged.
Old Jul 4, 2011 | 10:27 PM
xwhitchx's Avatar
I have tryed 5 tstats. And I have tested all of them in hot water at 170-180 and they all work just fine. I have no cel codes at all. I have ordered a new radiator so I hope the fixes my problem. Cuz even with the tstat out, the car is still a lil hot. And I have ran a car with out the tstat befor and the heat was way lower then this. So when I get the new radiator ill let you guys know what happens.
As for the heater core. How do I go about getting that out and were is it at??
Old Jul 5, 2011 | 06:46 AM
apexi_rsx's Avatar
the Heater core is under the dash and a royal pain in the *** to get to. u can bypass it to see if its the problem by looping the hose back into the motor. i don't think u need any heat anytime soon.
Old Jul 5, 2011 | 09:05 AM
xwhitchx's Avatar
Well Im going to be changing the dash out soon so that could be on my list of things to do.
Old Jul 5, 2011 | 08:16 PM
10 Year Member
Completely agree...if your car begins overheating on the high way or something, turn on the heater, and it will help disapate the heat, but i highly doubt that is your problem. But if you take out the heater core, you save a bit of weight....vroom vroom
Old Jul 5, 2011 | 08:19 PM
Former User's Avatar
Bleeding the cooling system may take 20-30 minutes:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below (hint: the bleed bolt is located where the upper radiator hose connects to the engine):
Old Jul 5, 2011 | 08:25 PM
10 Year Member
Great diagram ^^
Old Jul 5, 2011 | 10:27 PM
xwhitchx's Avatar
Thank you for the diagram. Ill give that a try when I get every thing installed.
Old Jul 11, 2011 | 11:47 PM
xwhitchx's Avatar
Fixed it It was the radiator. I got A new one with a slim fan for $75 shipped to my house. And its a lot nicer then my last ebay one.
