eg ac help
Old Jul 1, 2011 | 06:16 PM
Mr2Rotor's Avatar
Default eg ac help
For those with ac in there eg coupes or hatch can you please take a pic of the hoses from the firewall to the condensor cuz I'm lost. Please and thanks
Old Jul 1, 2011 | 06:33 PM
Ronnoc74's Avatar
Default Re: eg ac help
http://www.hondaautomotiveparts.com/.../17204_01.html
This helped me while I was installing mine. If you need actual pictures I can take some for you.
I have my ac system installed on my '93 hatch, just not charged or anything yet because I'm still having some problems with my blower turning on when I want it to. (https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/hvac-blower-problems-93-hatch-2951794/)
Old Jul 1, 2011 | 10:21 PM
Mr2Rotor's Avatar
I have my ac system installed on my '93 hatch, just not charged or anything yet because I'm still having some problems with my blower turning on when I want it to. (https://honda-tech.com/forums/showthread.php?t=2951794)
Can you please take pictures of the hoses from the firewall to the condensor and compressor please?
Old Jul 2, 2011 | 05:56 AM
Ronnoc74's Avatar
I have to leave for work right now, I snapped these real quick with my gopro. I'll take better ones when I get off work. Sorry for the huge pictures but I figure the bigger they are the more you can see. I didn't have time to move my battery to show you exact pictures of the firewall but on an R134a system the larger, fatter hose goes on the top and the skinner hose goes on the bottom when connecting it to your evaporator. When you get the the radiator area the fatter hose goes underneath your radiator. The skinnier one goes in front of it like in the picture.
Like I said I just snapped these real quick. I'll take better ones later on when I get off if you need me to. Just let me know.
Hope you can figure it out.
Old Jul 2, 2011 | 06:43 AM
instructor74's Avatar
here is the link to the oem install manual shows how to install all the lines
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-95-civic-ac-install-manual-2952290/
Old Jul 2, 2011 | 03:57 PM
Mr2Rotor's Avatar
Found out lines were for R134a and my car was R12 ****ing 93
Old Jul 2, 2011 | 05:14 PM
Ronnoc74's Avatar
as long as everything you bought for the ac is R134a you should still be able to use it. I have R134a lines and evaporator and all from a '95 sedan and my car is a '93 too. Just as long as you don't mix and match the lines from R12 to R134a you should be good.
Old Jul 2, 2011 | 05:38 PM
lillthingz's Avatar
If you mix the r-12, and r-134 it will create a poisonous gas so watch yourself when messing with that stuff. Also you will need to have the system vacumed at a shop to get the moisture out, and you will not be able to put the right amount of freon in it.
Old Jul 2, 2011 | 06:49 PM
Mr2Rotor's Avatar
Well I have the lines, compressor, condensor and drier. Only problem is the evaporator holes are too small for the R134a. If I buy the evaporator will everything work? Are the plugs under the dash the same for the R134a evaporator?
Old Jul 2, 2011 | 10:39 PM
93ludefreak's Avatar
the lines and evaporator built for r12 are a bit diffrent from those of r134a. if you have r134a lines you want to get the evaportaor 134a also. even if you wanted to mix and match they are bult diffrent. both will fit in your car either way, they just wont fit with each other.
I had a similar problem.
my 1993 lude had no ac components, built in canada therefore no ac. I went to a salvage yard and bought all r-12 components, exept for lines; planning to retrofit the system. afterwards at a diffrent yard i found the lines exept they were 134a and did not fit with what i had initially purchased. finally i found all r134a components on craigslist to fit my hoses(sinse i couldnt get a hold of r12 hoses anywhere) and put it in my car. It was a definite brainkiller since i had no idea how everything was supposed to look. now everything is in place exept for my compressor.
The evaporator, condenser and compressor all have an elecric plug. I found the plugs for my evaportaor and condenser hidden (im guessing the vehicle came without ac from factory but still left the plugs as an option). However i was never able to find the one for my compressor and thats where im sitting at right now. somebody messed with the cables near where my compressor plug should have been and now i have no clue which cable im supposed to hook it up to. heads up in case you have a similar problem.
I went again to a salvage yard and was able to find the plug for the compressor wich was hooked to a red cable with a series of black intermitent black spots in pairs. I was real happy thinking i could go back to my car and just find a cable with the same description and just plug it up, yet i still have not found it. Also inside my car where the ac button is supposed to be, i just have a black "dummie" button and again have no clue how im supposed to finish up.
hahaha. im sorry I started giving you advice and ended up exposing my own problem. im new to honda tech and im still not allowed to begin new threads. so if you have a similar problem and figure out how to solve it let me know. if anyone else has a tip i will deeply appreciate it.
Lastly. You dont need to go to a shop to vacuum your system. I had rented the pump from auto zone thinking i was ready to go when i unconvered my problem. Auto zone will rent you the vacuum pump you need and the gauge manifold you will also need for $300. once you're done you return it and get every cent back. if you dont know how to follow the procedures for usage let me know and i can walk you trough it.
good luck
cryptt0
Jun 5, 2015 09:04 AM
sktr9752
Aug 15, 2011 08:19 PM
sii.
Aug 30, 2007 09:48 PM
trust01
Oct 13, 2004 02:48 PM
