front door and fender removal help
can someone please share some knowledge with me on how to take off my 2001 honda accord coupe drivers side door not panel but the whole door? and also the drivers side fender i wrecked it and i need to replace those parts. thank you
on my 92 4-door, the panels are just held on with plastic fasteners. you can pop them off with a pair of flat screw drivers. as for the fenders, idk
Remove fender first.
Gotta start by removing the headlight, then the splash guard in the wheel well (might as well remove the wheel too), There's also a bunch of 10mm bolts on the top of the fender which you'll see when you open the hood. Next step is to remove the driver's sideskirt which will expose a 10mm bolt hidden underneath. There should also be another 10mm bolt behind the rearview mirror which you can access when opening the door slightly.
After fender is off, the door hinge bolts will be exposed and it's self explanatory from there. Be sure to unplug the door harness before you end up with a big heavy door in your hands and a harness that's still plugged in.
El_Jdm_Junky
Apr 19, 2009 07:46 AM
