off topic!how do i paint rims(gsr)hyper black,so they look like i power coated them?
Old Oct 1, 2002 | 06:18 PM
SiFoeLife's Avatar
Default off topic!how do i paint rims(gsr)hyper black,so they look like i power coated them?
some 1 please tell me the steps to paint rims so they look clean and wat kind of paint do i use.i know its off topic but i wanna paint mine.thanks!
Old Oct 1, 2002 | 06:20 PM
navin's Avatar
Default Re: off topic!how do i paint rims(gsr)hyper black,so they look like i power coated them? (SiFoeLife)
wtf is hyper black...anyways this is what I did to my HX's and flat blacked em..
1. degrease
2. sand (320 grit)
3. spray light coat of flat black paint
4. more light coats
5. then once everything is covered, more coats of flat black (we did like 3-4)
uhh yah...
Old Oct 1, 2002 | 06:29 PM
SiFoeLife's Avatar
Default Re: off topic!how do i paint rims(gsr)hyper black,so they look like i power coated them? (navin)
wat kind of name brand paint do i buy?wat did u use? thanks man
Old Oct 1, 2002 | 06:50 PM
EpDarks's Avatar
Just use paint that is meant to stick to all kinds of metals.
A friend ended up using one can per wheel, plus primer. So plan on buying a lot.
Old Oct 1, 2002 | 07:28 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: off topic!how do i paint rims(gsr)hyper black,so they look like i power coated them? (EpDarks)
Use Krylon and only Krylon. They got ultra flat black, flat black, gloss black, and high gloss black. Wash the wheels good, use at least 320 grit sandpaper or a scuff pad, then wash the wheels again. Spray a light coat of sandable primer over the entire surface(will leave kinda rough), and let it set for a few, and follow with a few regular coats of primer. You can wet sand that down for smoothness, or, leave it, depending on how it feels. Then always start with a light coat of paint, completely covering the surface, to make sure pain is sticking well, then apply as necessary. At least 4 good coats should be fine, but do as much as you'd like. Post pics when done!!
kaluwa3
Oct 12, 2008 07:00 PM
dan_w_82
Feb 13, 2005 08:44 PM
DaveF
Sep 23, 2003 03:15 PM
The Alchemist...
Aug 7, 2003 03:27 PM
RacerBoy
Apr 1, 2003 10:00 AM
