1996 Integra Turbo B18C1 & AEM EMS Install
No-Traction = Fun
Ill be installing the AEM EMS soon in my 96 integra with a Turbo B18C1 engine. My question is what startup program do I need to run. Is there some basic base map that I can pull up somewhere?
Here is my build sheet.
B18C1 BUILD SPEADSHEET
PARTS DESCRIPTION
Head Work 3 Angle Valve job
Head Work Resurface the head
Head Work Clean hot tank
Valves 1mm oversized valves
Valve Springs Dual Valve Springs
Spring Retainers Titanium Retainers
Valve Stem Seals Viton Valve Steam Seals
Block Work Hone & Bore block
Block Work Clean hot tank
Block Work Decked (resurfaced)
Block Work Micro polish the crank
Pistons Weisco Turbo Pistons #K541M815 81.5mm 8:87.1
Rods Revmaster H-Beam Rods
Crank Shaft OEM GSR Crank Shaft
Crank Pulley Fluidampr Harmonic Dampers #590601
Oil Pump OEM Type-R Oil pump
Water Pump/belt OEM water pump + OEM Belt + Hondabond
Rod/Main bearings ACL Race bearings (set)
ARP Head Studs ARP head stud bolt kit # 208-4303
Head Gasket Cometic 81.5mm bore .027"
Full Gasket kit Valve cover + plug gaskets + gromets
Full Gasket kit Aftermarket complete gasket set
Oil Pan Moroso 4qt Oil Pan #20911
Oil Switch Oil pressure Sending Switch
Oil Plug Magnetic oil pan plug
Intake Manifold BBK Intake manifold # 5007
Injectors Precision 720cc Fuel Injectors
Fuel rail AEM high flow fuel rail (black) 20-100BK
Fuel AEM adjustable fuel pressure
Throttle Body BBK Throttle Body 70mm #1547
Fuel Pump Walbor 255 Fuel Pump
Clutch Kit XTD Stage 5 (4puck sprung hub)
Gaskets Thermal intake Gasket
Flywheel XTD 12lb flywheel
Radiator Aluminum 2-row Radiator
Catch Can setup Custom valve cover/catch Can
Hose Kit Mishimoto Silicon Hose Kit upper/lower
Gauges AEM UEGO Wide Band #30-4100
Gauges AEM Tru-Boost #30-4350
Gauges AEM Water Temp #30-4402
Gauges AEM Oil Temp #30-4402
Gauges AEM Pyrometer #30-5131
Gauges AEM Fuel pressure #30-4401
Gauges AEM Oil pressure #30-4401
Gauges AEM Water/meth flow #30-5141
Water/Meth AEM Water methanol injection #30-3000
LSD Limited Slip Differential Quife
Engine Management AEM EMS system
Map Sensor Omni Power 3 Bar map
Turbo Stuff Custom "Silver Surfer" Turbo
Engine Stuff New Engine knock sensor
Turbo Stuff Full custom manifold and downpipe
Turbo Stuff Tial Waste Gate
Oil Cooler Kit Oil Cooler kit + samwitch adapter
Turbo Stuff Synapse Synchronic Blow Off Valve
Turbo Stuff Oil feed and return lines
Turbo Stuff full 3" mandral piping
Turbo Stuff 3" race cat
Turbo Stuff 3" x 22" resinator
Turbo Stuff 3" magnaflow muffler
Tune Bisimoto Engineering Tune/Dyno W/AEM EMS
PARTS DESCRIPTION
negroeg6
Northern California (Sales)
24
May 18, 2011 03:49 PM
