Full gsr swap b16 tranny turn key everything you need
Old Jun 30, 2011 | 04:41 AM
2ndcoming's Avatar
Default Full gsr swap b16 tranny turn key everything you need
94 gsr swap it's coming out of an Ek
engine was rebuilt 5,000 miles ago
new oem b16 pistons, rings and pins bumping comp to 11.3:1
new oem oil pan gskt
new oem seals cam, front and rear main
new oem water pump
new oem timing belt
new oem valve seals
super tech tiretaniers and valve springs
new blox intake manifold with thermo gskt
new blox 68mm t/b
hyatech rep tri-y header
b16 tranny being rebuilt bought it off a member on here and had a bad 2nd gear syncro should have it back next week
comp clutch stg 2 clutch kit
7.5lbs flywheel
chipped p72 ecu
jumper harness
rc 370 inj
shift linkage
brand new a/c comp
all engine mounts
this is a full swap turn key
the swap runs flawless I've got close to $4,000 in it, I'm very picky and my **** has to be perfect that's why I've put so much money and time into this one. Your getting everything to drop it in and go. If you think I'm asking to much kick rocks. This is a good price for pieace of mind I've been ****ed over way to many times to do it to any one else.
$2500 obo
also have crower stg3 cams and skunk2 cam gears $500
also a full direct port nitrous kit with 780cc inj $400
need money for bills no trades unless it's cash
Old Jun 30, 2011 | 08:49 AM
2ndcoming's Avatar
Default Re: Full gsr swap b16 tranny turn key everything you need
Bump
Old Jun 30, 2011 | 04:19 PM
2ndcoming's Avatar
Bump
Old Jun 30, 2011 | 08:12 PM
Surfjunkie44's Avatar
If you have already completed building the motor, you should leave it in... but in the same regard, I understand the "bills" issue. Give me a call when you get this; we should talk ASAP.
Bradley
407.233.7886
Old Jul 1, 2011 | 03:52 AM
2ndcoming's Avatar
The motor is in the car running I finished building it 3months ago put abot 5000 miles on it
Old Jul 1, 2011 | 06:55 PM
2ndcoming's Avatar
Bump
Old Jul 2, 2011 | 08:47 AM
2ndcoming's Avatar
Old Jul 2, 2011 | 12:22 PM
2ndcoming's Avatar
Bump
Old Jul 2, 2011 | 09:21 PM
2ndcoming's Avatar
Bump
Old Jul 3, 2011 | 10:20 AM
shizkabob3421's Avatar
willing to part it out if so ill buy the shortblock.
Old Jul 3, 2011 | 03:14 PM
2ndcoming's Avatar
How much and what all do you need
Old Jul 3, 2011 | 04:59 PM
2ndcoming's Avatar
Bump
Old Jul 4, 2011 | 06:12 AM
2ndcoming's Avatar
Ttt
Old Jul 4, 2011 | 09:14 PM
pretty much take the tranny and head off and thats what i want.let me know a price.
2ndcoming
Oct 5, 2011 05:09 PM
shadydb7
Northeast (Sales)
33
Dec 21, 2009 04:43 PM
siboy101
Mid-Atlantic (Sales)
16
Apr 22, 2009 04:05 AM
cranberry
May 25, 2007 08:10 PM
koolb
Northwest (Sales)
Nov 18, 2005 02:41 PM
