Suspension & Brakes Theory, alignment, spring rates....
1999 civic hatch dx struts fitment
Old Jun 29, 2011 | 06:57 PM
hymn's Avatar
Default 1999 civic hatch dx struts fitment
i have a 1999 honda civic dx complete stock and i'm planning to drop the car sometime soon.
i'm still a newbie at this but when u buy struts/coilover for a civic, u buy it base on the body style and not the engine or 5lug(example itr) correct? or do i have to get the struts/coilover base on the engine and the 5lug suspension?
Old Jun 29, 2011 | 07:47 PM
hunan beef's Avatar
Default Re: 1999 civic hatch dx struts fitment
Nope. For you.. you would need any setup for 96-00 Civic. Front shocks are pretty much interchangeable between 92-95 Civics and 94-01 Integras. The rear shock on the 96-00 civic is a bit different then the EG civic or DC Integra.
Old Jun 30, 2011 | 04:41 AM
hymn's Avatar
Sorry if I'm not explaining this clearly but as of now i have a single cam engine and 4 lug suspension of course. If I was to put Coilover/struts right now and later in the future swap a 5 lug maybe, would I be able to use the same coilover/struts or do I have to use One that comparable with a 5 lug setup
Ps I don't know if this will make it easier but I'm planning to go with koni yellow with ground control sleeve
Old Jun 30, 2011 | 06:52 AM
kyden's Avatar
yes you can use it. the 5 lug swap has nothing to do with the spring/shock setup. btw you have shocks, not struts.
Old Jun 30, 2011 | 09:08 AM
hymn's Avatar
Ah okay. Thankyou for the help
Si-ONARA
May 28, 2008 11:01 AM
DFW
Suspension & Brakes
Jun 21, 2006 12:09 PM
em1_mark
Dec 7, 2005 12:38 PM
pu5sipoppr
Suspension & Brakes
Mar 12, 2005 08:05 PM
oem
Apr 5, 2003 12:45 PM
