95 Lx help
Old Jun 29, 2011 | 02:56 PM
Scotty_06's Avatar
Default 95 Lx help
Hey, looking for some help to point me to the right direction.
My 1995 Lx 2.2 non vtec is throwing code 8, Top dead center sensor. I have done a ton of reading on this forum and I have got all kinds of differnt answers. The TDC sensor is the Crankshaft sensor? Right? Also, this is located behind the pully, correct? I have read so many differnt threads as the where they are located. I took a look under the car, but couldn't get any where.
Old Jul 3, 2011 | 11:32 AM
Scotty_06's Avatar
Default Re: 95 Lx help
Bump! Anyone??
Old Jul 3, 2011 | 12:35 PM
dglassmyer's Avatar
Yes the crankshaft position sensor is located at the bottom timing belt crank pulley, it is mounted on the block behind the lower timing belt cover which is why you can't see it, there is a 4 wire hookup running down the back side of the timing cover that you can follow to help locate it, it should be noted its not quick to change this sensor as you have to remove the entire cover, timing and balance belts to access it, make sure your wires leading to it are in good shape, they tend to get covered in oil
Old Jul 3, 2011 | 03:46 PM
nus_dogg's Avatar
Are you guys sure it's not in the distributor? I don't know as I've never deal with that code.
Old Jul 3, 2011 | 06:26 PM
MAD_MIKE's Avatar
MM Gruppe B
I concur, I believe on the 94/95 any sensor would be in the distributor. 96/97 cars have the crank sensor. I don't recall there being any sensor or wiring down that low on the '95 EX.
Old Jul 3, 2011 | 07:32 PM
chikin pickle's Avatar
The TDC sensor is located inside the distributor in OBD1 accord (94/95). It's part of a sensor assembly in there. If it goes bad, the whole dizzy has to go.
Old Jul 3, 2011 | 09:01 PM
Scotty_06's Avatar
Okay, so the car being an OBD1, the TDC sensor is the dizzy? SO I need to replace the whole dizzy, right? Thanks for the help everyone!
MacMade
Sep 14, 2020 12:09 PM
Mustang72
Honda Civic (2001 - 2005)
Dec 1, 2014 08:04 PM
tougeem2
Nov 15, 2011 05:39 AM
Jams_Civic
Apr 8, 2008 09:24 PM
drowzysleeper
Mar 21, 2005 09:47 AM
