H22 swap??
New to this. Guna do H22 swap into a 99 civic ex. Have the H22 BUt no harness will my civic harness convert? not sure wht year the motor is.Also What all will i need to complet the swap?? any help would be great thanks..
Indeed, it's easiest to use the stock harness and just wire it for the new engine.
Your question is very vague. You need a lot of things for the swap. H2b kit, mounts, transmission, alternator, header, belts, radiator hoses, etc.
Im running a p2t obd2(00 si) ecu with a stock harness. I got my h22(94) complete and bought hasport mounts for it. Im also using the h22 LSD tranny it came with I just had to drill the shift linkage holes a tad bit higher. Also I had to buy 93 DA integra axles and an aftermarket radiator. That pretty much sums up my swap other than fixing about 5 c.e.l's to convert obd1 to obd2. If your H is 97+ the wiring part is cake.
slo_hatch
Mar 31, 2008 04:27 PM
-Bionic-
Sep 8, 2003 06:55 PM
