cv boot/axle price
Old Oct 1, 2002 | 05:12 PM
93accordEX's Avatar
Default cv boot/axle price
well I noticed a little puddle under my car the other day. couldn't figure out what it was. I was changing my rims and found the cv boot was torn. Nothing seems to be wrong with the car though, what are symtoms of this? and how much is it to replace an axle, or just the boot if that is possible, and are there aftermarket axles made, or would I have to go custom to get something better than stock. Thanks
Old Oct 1, 2002 | 05:13 PM
CD8's Avatar
CD8
Default Re: cv boot/axle price (93accordEX)
just get a rebuilt one. they should run around $75. you can install it yourself
Old Oct 1, 2002 | 05:27 PM
briq4's Avatar
Default Re: cv boot/axle price (exaccord)
What would happen eventually is that dirt/grime/water would get in the joint and basically cause it to wear itself apart, and eventually fail. But like he said not too expensive and not impossible to change.
Old Oct 1, 2002 | 08:02 PM
N3M3S1S_F0X's Avatar
I just had that all replaced on my 95. The axles were starting to rust pretty bad and the joints were loosening up. Had the whole deal done with new aftermarket axels/joints/boots (all cept boots came with lifetime warranty) for about 500. Could have waited longer but Wisconsin's salty winter roads really **** everything up.
[Modified by N3M3S1S_F0X, 5:03 AM 10/2/2002]
Old Oct 1, 2002 | 08:18 PM
BreakStuff's Avatar
New User
About $150 per side parts and labor...
your mileage may vary..(thats pun )
Old Oct 8, 2002 | 11:52 AM
Decepticon2001's Avatar
where would I find a rebuilt axle? I've been looking and can't find it, and my friend told me that it's better if I just buy a new one. , how long do you think I can drive my car with a messed up axle?
[Modified by Decepticon2001, 8:53 PM 10/8/2002]
Old Oct 8, 2002 | 02:00 PM
urbanlegend21's Avatar
New User
Default Re: cv boot/axle price (Decepticon2001)
you can pay $79 dollars to an auto parts store and get a axle that is rebuilt after being reground. I just replaced 6 axles in my car in a matter of a month and a half because of that regrind bullshit. I then went RAXLES and bought a OEM replacement w/o regrind for $120 and the problem went away. For quality axles RAXLES is one of the best deals out there.
Is your car lowered? If it is lowered more than an inch then the boots will actually rub on the splines because of the change in geometry.They will also be under more stress on the inner CV becuase of the angle. This will cause them to split or heat up and split. Or they are just old boots. All in all it is almost more efficent to buy a new axle then an aftermarket boots, especially the aftermarket split boots.
chris89
Transmission & Drivetrain
Aug 28, 2015 09:51 PM
EJ8 GSR-T
May 17, 2007 07:19 PM
gooberwolf
Sep 6, 2003 12:05 PM
lahight
Sep 3, 2003 01:26 AM
FUP23
Jul 13, 2002 09:53 PM
