caliper bridge bolt stuck
Old Jun 28, 2011 | 10:57 PM
efeher's Avatar
Default caliper bridge bolt stuck
the two bolts that hold the caliper bridge on are rusted/overtightened stuck. i tried a 22" breaker bar and an impact wrench with penetrating oil, any other ideas?
Old Jun 29, 2011 | 12:20 AM
Joeynapp's Avatar
Default Re: caliper bridge bolt stuck
Heat ALOT of heat. Propane torch hold on the bolt for about 3-5 mins then use the breaker-bar. Just don't burn your self or the hose. Heat will become your best friend in situations like these..
Old Jun 29, 2011 | 01:03 AM
efeher's Avatar
I thought heat may work, i was just worried because the axle boot and the rubber caliper bushing are close. I was planning on covering these with a wet towel, are there any other parts i should protect?
smmcla
Suspension & Brakes
12
Sep 17, 2024 08:07 PM
732xghost
Jun 20, 2009 04:55 PM
deeweezy187
May 13, 2006 09:29 PM
EGhatch33
Suspension & Brakes
24
Jan 2, 2006 10:01 AM
AndrewD
Jan 22, 2005 12:10 PM
