Lawnmower Battery in CRX...
Old Oct 1, 2002 | 04:57 PM
twincamrex's Avatar
Default Lawnmower Battery in CRX/Civic...
Anyone running a lawnmower battery or motorcycle battery in their ef's? Im looking into using a lawnmower battery instead of relocating it to the back. Im not sure how much space it will free up in the engine bay.. i think i read somewhere that a person fit a 99-00 si CAI on their b16a in a crx with just putting in the lawnmower battery. Anyone know if this is possible or not? Thanks for the help. Pics would be great.
[Modified by twincamrex, 1:57 AM 10/2/2002]
Old Oct 1, 2002 | 05:57 PM
allmotorEG-SI's Avatar
Default Re: Lawnmower Battery in CRX/Civic... (twincamrex)
just get a drycell , probably better that way anyhow.
Old Oct 1, 2002 | 06:03 PM
keebler65's Avatar
yeah the typical max power of a lawn batt is 300cca or so. most hondas take 400-500 recommended. do what was said above and get a drycell. that way you dont have to worry about anything venting (acid) into your trunk. can you tell i used to work at batteries plus?
Old Oct 1, 2002 | 06:18 PM
philly-O's Avatar
Default Re: Lawnmower Battery in CRX/Civic... (keebler65)
batcap makes a model 800 batery. it is the size of a motorcycle battery. it weighs only 10lbs and resting voltage is 13 volts. you can find them online for $169 plus shipping and they are 800 cca.
Old Oct 1, 2002 | 06:32 PM
Default Re: Lawnmower Battery in CRX/Civic... (peichie)
I don't know much about electricty, but isn't a honda a 12 volt so wouldn't 13 overload the wiring and possibly cause a fire.
Old Oct 1, 2002 | 07:22 PM
CRX7's Avatar
Default Re: Lawnmower Battery in CRX/Civic... (gixxerdemon)
That's why you have a regulator, to keep the voltage at the correct level.
Old Oct 1, 2002 | 07:23 PM
ScottEK's Avatar
Not at all, if you watch your voltage the range varies widely, I've heard in most audio setups 13.7volts is a good normal voltage.
Old Oct 1, 2002 | 09:35 PM
philly-O's Avatar
Default Re: Lawnmower Battery in CRX/Civic... (beta13)
running voltage is usually 14.4 and idle voltage is usually 12.8
Old Oct 1, 2002 | 09:50 PM
Redline130's Avatar
I have a Baker Precision battery, weighs 15lbs. It's pretty small, but it effortlessly cranks the motor over. I don't know about daily use though, I have this in my race car.
Old Oct 1, 2002 | 11:58 PM
RenoRacing's Avatar
Default Re: Lawnmower Battery in CRX/Civic... (cyber13)
my friend ran one of these for a long time without any problems, i like how much room i freed up with my relocation and still kept weight over the front tires!
Old Oct 2, 2002 | 04:02 AM
AussieK24's Avatar
Default Re: Lawnmower Battery in CRX/Civic... (HavokRacing)
Yeah I run one and have had no problems. My car has no sterio or power anything tho...
Old Oct 2, 2002 | 10:34 AM
speedracer33's Avatar
Default Re: Lawnmower Battery in CRX/Civic... (b16a4me)
I ran my CRX racecar on a lawnmower battery for a couple of years, no problems.
Matt
Old Oct 2, 2002 | 08:41 PM
ExospeedAMcrx's Avatar
we have a battery relocaton kit that mounts on the Crossmember. The kit uses a Baker 330cca lightweight battery.
Wil
Kagelude
Aug 31, 2006 09:13 AM
BlackThorN
Audio / Security / Video
15
Jun 27, 2004 01:31 PM
pyro_freak8
10
Jan 8, 2004 02:27 PM
Mike P.
12
Nov 14, 2001 12:34 AM
