Driver window rolls up crooked on '90 DX hatch.
Old Jun 28, 2011 | 03:46 PM
socialistic's Avatar
Default Driver window rolls up crooked on '90 DX hatch.
I've been having this problem with the driver window rolling up crooked, it has some wobble to it and it is tilting forwards. I have to press it out and also towards the rear for it to roll up properly and even then it doesn't seal properly when closed, and rain water is getting in the the car and down inside the door.
I took the panel off and can't seem to find anything wrong, missing, or odd-looking. What could the problem be?
Old Jun 28, 2011 | 03:56 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Driver window rolls up crooked on '90 DX hatch.
It's got a gangsta' lean!
I've had this problem on several cars.
To fix it, I roll the window all the way up the best I can, take off the door panel. and then loosen up the bolts that hold the window to the rail.
Set the window where it ought to go and then tighten up the bolts.
If that doesn't fix it, leave the panel off and roll the window up and down a few times to see what is going on.
Old Jun 28, 2011 | 04:06 PM
Deetz's Avatar
Crazy Honda Guy
Silicon spray inside your run channels with help also
Old Jun 28, 2011 | 04:27 PM
I've greased the rails and channels, rolled the window up and down, tilted it back and forth, I can't seem to figure out what exactly is loose/missing/broken. Everything looks fine except the window tilts towards the front of the car and has a lot of play in it.
Old Jun 28, 2011 | 05:00 PM
Deetz's Avatar
Crazy Honda Guy
greased it? with what, lol
Old Jun 28, 2011 | 05:01 PM
With fresh grease.
Old Jun 28, 2011 | 05:05 PM
Deetz's Avatar
Crazy Honda Guy
^^oh no, terrible idea, you probably made it worse
Old Jun 28, 2011 | 05:07 PM
I've been using grease on window assemblies, power and manual, for years, never had any issues. Plus the crap I've cleaned out of those rails definitely looked like old grease to me, so I'm assuming that's what Honda used when they built these.
Old Jun 28, 2011 | 05:16 PM
Deetz's Avatar
Crazy Honda Guy
I worked for Honda...they use silicone only. There are two types....
The paste (pictured below) or a spray
Old Jun 28, 2011 | 05:18 PM
Hm, learn something new every day. I still don't see why grease would be a bad idea, unless it was a low-grade/cheap crappy grease. I have this blue grease that I use on damn near everything and it's fantastic, I especially used it on several of my Integras when I had to replace old window motors. Never had any issues and the windows worked beautifully with the new grease.
Old Jun 28, 2011 | 05:25 PM
Deetz's Avatar
Crazy Honda Guy
Grease picks up dirt, then gets gunked up over time, that is why
Old Jun 28, 2011 | 05:27 PM
Yeah, you've got a point there. My cars have always been in pretty decent shape and I keep them very clean, so I guess that problem isn't as common for me as it would be for others.
Either way, this window is still being a pain in the ***. I have an Si parts car here from the same year, I'll take a look at the driver window assembly on that one and see if I can figure out what the problem is.
Old Jun 29, 2011 | 07:06 AM
Still couldn't figure out what the problem was and chalked it up to nothing more than a worn-out regulator assembly. Replaced with a very good condition one out of a spare door I had laying around, window rolls up/down just fine now.
Old Jun 29, 2011 | 08:30 AM
garthjenkins's Avatar
replace the window regulator....done
dgmorr
Jul 16, 2005 02:02 AM
Jonathan_ED3
May 9, 2005 11:42 AM
LSvtec03
Oct 17, 2004 04:58 AM
SlammedHatch90
Jan 31, 2003 03:49 PM
