will the ecu from an 88 prelude si work?
Old Jun 28, 2011 | 01:45 PM
jarhead90crx's Avatar
Default will the ecu from an 88 prelude si work?
I have a 90 crx si with a b18b1 swap that was converted back to obd0. Will the ecu from an 88 prelude 2.0 si work? Neither engine is vtec. Very important that I find out soon lol
Old Jun 28, 2011 | 04:45 PM
netfreak's Avatar
Default Re: will the ecu from an 88 prelude si work?
You'll want to use the PR4 from a 90-91 Integra. The prelude ECU may run the car but it won't run right.
Old Jun 29, 2011 | 04:15 AM
anjin's Avatar
You will find the prelude ecu will provide fuel for a 2 litre engine with whatever size injectors the prelude engine uses. If the injectors are the same size, and thats a fair chance, then you will be running a bit rich.
And then the ignition will be set up for the b20 as well. Might be the same map as a b18, but maybe not as well.
I'd go with the ecu that matches the engine as well.
Kchambers
Jul 18, 2009 08:16 AM
Fusion G2 Civic
Jan 10, 2006 07:49 PM
