Shift control solenoid valve a location on 96 accord???
Old Jun 28, 2011 | 12:36 PM
Chmura's Avatar
Default Shift control solenoid valve a location on 96 accord???
I have a 96 accord ex automatic 2.2 i4
My D4 started flashing and the car fails to shift into 2nd gear so I'm forced to switch it manually.
Doing the paper clip method I discovered it's the shift control solenoid valve a connector, wire or solenoid itself are faulty.
I have no idea where these are connected. Where do I look for this?? Easy to replace??
A diagram or picture would be great
Old Jun 28, 2011 | 12:52 PM
GhostAccord's Avatar
Default Re: Shift control solenoid valve a location on 96 accord???
They are located mounted to the top/front of the transmission housing. Close to the center engine mount.
The A & B shift control solenoids are the two cylinders that are lower down on the trans housing. The two upper cylinders are the A & B lockup control solenoids.
Old Jun 28, 2011 | 01:29 PM
Chmura's Avatar
Perfect. I got lucky it was only a lose cable, needed to push it in
Thank you so much!
Old Jun 28, 2011 | 01:31 PM
Your welcome.
Those are the best kinds of repairs.
flipper7
Oct 24, 2013 07:16 PM
hack
Aug 8, 2011 07:41 AM
alsarabi
Nov 30, 2006 06:54 PM
aofemi
Jan 5, 2006 05:16 AM
