Question for all track guru's
When your booting around a track, done suspesion and all. What's the rpm ranges do you use, tight corners, fast corners, banked...and all the rest.
The only tracks I can relate to is Cayuga (Toronto Motorsports Park), Mosport and Shannonville. If you know these tracks pleaze answer, Thanx.
When your booting around a track, done suspesion and all. What's the rpm ranges do you use, ....
Redline whenever possible!
You going for a peaceful touring lap or for some spirited driving?
Thanks, I figured you might hit redline, but Iask "What RANGE of rpm?"
Going around the track - any track - you should keep the R in the lowest gear you can without exceeding redline. That means that your revs will be as high as possible, and will vary from somewhere around 5500-6000 or so immediately after upshifting, to 8400, all the way around the track. Tight corners (ones where you're significantly slower than 60 mph) you'll be in second gear, and fast corners in third, but you'll still be keeping your revs up, regardless.
Booting in canadian means ***** to the wall in amercan
Not lower than 5K with the Mugen computer in my ITR, and not more than 9K!
LOL! EPG ... oil pressure
Stinkycheezmonky
16
Sep 17, 2005 10:39 PM
artifex
15
Jul 7, 2005 10:20 PM
