'90 Accord DX, Falling apart
Old Jun 28, 2011 | 09:52 AM
FL4T's Avatar
Default '90 Accord DX, Falling apart
hey, here's the cliche first forum post complaining about car troubles...
im new to the honda world as i just bought a 1990 accord dx with 218k, to daily drive while i complete my subaru project
problems:
very rough idle
transmission (AT) wont shift under constant acceleration (kick down?)
acceleration is horrible, takes maybe a minute or longer to reach freeway speeds..
it doesnt do hills. at all.
wont go over 60mph
blinking CEL, i cannot find the '2 pin connector' used to read codes anywhere (pass side under the dash, didnt see it)
got some overheating and light smoking after about a 40 mile mostly freeway drive
and the fan stays on for a bit after i shut the car off and remove the key
but.. the body and interior is pretty good for a car as old as i am
anyways.. hit me with the onslaught of tech advice
FL4T's Avatar
Default Re: '90 Accord DX, Falling apart
okay, so i found the diagnostic plug, with a switch on it instead.. so thats confusing the **** out of me
it looks like it was in the position of shorting the two wires to begin with, because when i switch it off, the cel turns on with the other lights, then turns off as if theres no code, when the wires are touching (switch turned 'on'), the cel blinks slowly..
so..?
Old Jun 29, 2011 | 01:34 AM
GhostAccord's Avatar
If the CEL is flashing slow with the SCS connector shorted when you are not driving those are more than likely stored codes.
A flashing CEL while driving indicates a misfire issue. Check your spark and fuel.
Sammie Gonzalez
Engine Management and Tuning
Jun 19, 2019 02:42 AM
accordtuna
Dec 20, 2018 12:45 PM
Kibbster
Classic Hondas
Nov 4, 2017 11:32 AM
1988HADX
Classic Hondas
43
Jul 3, 2011 06:23 AM
