Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
trunk hard to lock
Old Jun 28, 2011 | 06:44 AM
jasrams's Avatar
Default trunk hard to lock
I saw a link up once where someone was seeking assistance with their trunk. I am having similar problems the trunk only locks after two attempts and when i slam it hard which i should not do as it use to lock good before this. please help pics would be an asset.
Old Jun 28, 2011 | 09:08 AM
K24_Y61P's Avatar
Default Re: trunk hard to lock
The bump stops could be stopping it from closing. Well at least i think the trunk has bump stops. If it does try turning those inward a bit. If I'm wrong and it doesn't have bump stops, its your latch.
Old Jun 28, 2011 | 11:11 AM
It Wasn't Me's Avatar
Try adjusting the striker. (the metal "loop" that the latch locks on when you close the lid)
Old Jun 28, 2011 | 11:59 AM
jasrams's Avatar
how do i adjust it?
Old Jun 30, 2011 | 01:45 AM
Tonyja's Avatar
misunderstood
Old Jun 30, 2011 | 07:54 PM
AutoXer's Avatar
That last post has nothing to do with your issue. There's two bolts on the 'loop' that the hood latches into. Loosen them up, and slide it towards you. Tighten them back up and you should be good.
Old Jun 30, 2011 | 09:30 PM
dr_spock's Avatar
Peel back the plastic trim and you should see the bolts.
Old Jul 1, 2011 | 06:51 AM
jasrams's Avatar
ok thanks will try this later
Old Aug 9, 2011 | 03:54 PM
jasrams's Avatar
how do i remove the plastic cover without breaking it?
Old Aug 9, 2011 | 07:04 PM
Pull up on it. It's held in place with metal clips.
Old Aug 9, 2011 | 08:20 PM
jasrams's Avatar
ok i started but stopped i felt as if i was breaking it
Old Aug 9, 2011 | 08:59 PM
The clips hold it in rather tightly, it'll make some noise and really "pop" when the clips come out. At least mine does.
Old Aug 10, 2011 | 08:04 AM
jasrams's Avatar
yea i heard the noise and stop lol lol ok will do it soon
Old Aug 23, 2011 | 07:37 PM
jasrams's Avatar
so i peeled the plastic back pulled the loop towards me and it still would not close. However i solved the probably. There is a small spring on the latch that apparently it was worn out so i replaced it and presto closes like a charm
streetsold6teeny8
12
May 19, 2009 05:12 PM
knightsef-eg
Suspension & Brakes
Nov 16, 2008 06:29 PM
popngen
Jun 7, 2004 06:29 PM
monkmonkman
Mar 18, 2004 09:23 AM
ButterMule
Jan 9, 2004 05:16 AM
