what ecu pin do i run my aem wideband to kpro
Old Jun 27, 2011 | 07:09 PM
bads2k's Avatar
Default what ecu pin do i run my aem wideband to kpro
trying to find the answer on which pin on the ecu to wire my aem wideband up to so i can datalog it. right now i'm just using the stock wideband and i want to change that. also do i disable the o2 sensor response at that point for the stock one?
Old Jun 28, 2011 | 04:16 AM
mtber's Avatar
Default Re: what ecu pin do i run my aem wideband to kpro
You can use the ELD pin.
Go to http://hondata.com/help/kmanager/index.html
Click on search, type wideband
Old Jun 28, 2011 | 06:18 AM
bads2k's Avatar
Uses the same voltage to air/fuel numbers as you would Input on aem management?
Old Jun 28, 2011 | 09:10 AM
mtber's Avatar
Yes, refer to the aem uego gauge install instructions for the voltage output.
crxb16a90
Engine Management and Tuning
Oct 25, 2010 12:03 PM
Momentum
Oct 19, 2010 12:07 PM
Top Ramen
Feb 25, 2009 01:35 PM
MJobe
Nov 22, 2006 05:50 PM
brnyrdcmndo
Mar 27, 2005 04:18 PM
