what spring rate should i get my ground control
Old Jun 27, 2011 | 12:01 PM
DA9Sleeper's Avatar
Default what spring rate should i get my ground control
hello im ordering my koni and gc set with top hats today or tomorrow. but before i order i want to know what spring rate i should get. im kinda going for the slam look but still going to DD the car and bring it to the track a few times .what would be a good spring rate. thank you
Old Jun 27, 2011 | 02:59 PM
racebum's Avatar
Default Re: what spring rate should i get my ground control
what tires will you be running? xs, ad08? star spec etc?
Old Jun 27, 2011 | 03:02 PM
00IntegrAllmotoR's Avatar
HT Black OPs
SEARCH!!!!!!!!!! Its been covered 1 Trillion times.
Old Jun 27, 2011 | 03:05 PM
racebum's Avatar
in the suspension forum yes but it's kind of a user specific thing. if someone is using an xs with big sway bars, wants to be a 1 finger gap...roughly, you'll use a 500/450 rate. if someone wants to autocross the same car they would use 500/500 or 450/500.
by autocross i don't mean once a year, i mean that's the priority setup
if you use a harder tire like the s drive rates come down since you won't have the kind of feedback you want with higher rates
Old Jun 27, 2011 | 03:50 PM
DA9Sleeper's Avatar
will i have some volks te 37 wrapped with Dunlop Direzza Sport Z1 Star Spec tires size 205 50 16S
Old Jun 28, 2011 | 04:11 PM
racebum's Avatar
tire is too tall, it's going to rub. 245 45 16 is the largest tire you want to use. best bang for your buck is 205 50 15
azzazel_99
Suspension & Brakes
31
Jun 21, 2012 09:42 AM
mechanix619
Suspension & Brakes
May 23, 2011 09:48 AM
JamesL
22
Jun 26, 2008 06:23 AM
mofuckinarnell
Suspension & Brakes
Jun 30, 2005 12:41 PM
The Punisher
Apr 19, 2002 07:12 PM
