My Vtec Wont Crack.
Old Jun 27, 2011 | 11:49 AM
BlueSmartEm1's Avatar
Default My Vtec Wont Crack.
i have an 2002 type s and few days ago vtec was not cracking and its still not.. i thought it would be gas or oil but i had changed that recently.. any help on what i can do to fix it? I WANT MY VTEC BACK!!! LOL. thanks.
Old Jun 27, 2011 | 06:35 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: My Vtec Wont Crack.
Any check engine lights?
Old Jun 27, 2011 | 07:30 PM
dc5itracer's Avatar
Damn that's bad vtec is supposed to pop not crack lol
Old Jun 27, 2011 | 07:38 PM
njn63's Avatar
Generally hearing things cracking is not a good sign.
Old Jun 27, 2011 | 07:57 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
I'm pretty sure you've all been trolled on.
Old Jun 27, 2011 | 09:03 PM
apexi_rsx's Avatar
wtf... stupidity on this forum anymore. wtf is vtec cracking; why not just say vtec is not engaging? your oil is prob low and its not good to rev ur motor out when vtec is not engaging. its not good to be in vtec rpm range without it engaging especially if your low on oil.
Old Jun 28, 2011 | 06:39 AM
Mr. Spade's Avatar
I autocrossed on 1 quart of old oil. Vtec still engaged.
Old Jun 28, 2011 | 03:48 PM
okkkk... sorry. v tec is not engaging.. better? there is oil i just changed it few days ago and there is also gas.. there also is no check engine light.. i reset the ecu then the vtec was working then it started not working again..
Old Jun 29, 2011 | 09:12 AM
apexi_rsx's Avatar
maybe try grounding the blk wire on the pressure switch on the vtec solenoid. use alligator clips or something if u want to do this temp or not. also to check if the solenoid works unplug the vtec solenoid and take a piece of wire and run it to the solenoid from the positive on the battery and see if u hear a "click" when u touch it on the prong in the solenoid plug.
Old Jun 29, 2011 | 09:37 AM
rattlecannedEF's Avatar
check your vtak fluid.
Old Jun 29, 2011 | 10:12 AM
CrAzE191st's Avatar
did you switch the kind of oil you've been using?
Old Jun 29, 2011 | 10:15 AM
m_shake's Avatar
Quit smoking crack and maybe vtakkk will return
Old Jul 3, 2011 | 04:21 PM
thanks for your guys help. but also when i try to reset the ecu. my vtec starts working again..? is that a problem?
Old Jul 3, 2011 | 09:26 PM
B serious's Avatar
Was the car warmed up when you were out there crackin that 'tec like homies do in the hood? It won't work unless the car is warmed up.
Also, does your check engine light even work?
blacktibby07
May 14, 2011 11:12 AM
offspringpunk14
12
Sep 23, 2009 07:16 AM
JSpekBB4
Oct 30, 2007 10:23 PM
vietnogi
Apr 13, 2005 10:01 PM
CompressionFed
Mar 23, 2004 04:54 AM
