about to perform JDM front end conversion...
Old Jun 27, 2011 | 09:40 AM
mikecp's Avatar
Default about to perform JDM front end conversion...
- JDM front bumper
- JDM Front bumper support
- JDM Front bumper filler
- turn signals
- corner lights
- JDM style headlights
- JDM Style fenders
- JDM Style Hood
is there anything else I would need?
Old Jun 27, 2011 | 10:03 AM
crx_si-r's Avatar
Default Re: about to perform JDM front end conversion...
fenders and corners are not needed, but if they came with the front end then use em. if you dont have the T-Bar then you will just need to space out your stock T-bar about 1/2" with washers n longer bolts. other than that sounds like you have everything.
you will also need to do some wiring for the headlights to work properly. if you need a plug n play adapter lmk i can make them. this way when high beams flash the low beams cut off. this extends bulb life. lmk
Old Jun 27, 2011 | 10:07 AM
mikecp's Avatar
i have USDM fenders now. aren't the JDM fenders longer or taller?
Old Jun 27, 2011 | 10:26 AM
crx_si-r's Avatar
nope. they are identical, except of course for the side marker light cut outs. other than that they are the same.
Old Jun 27, 2011 | 10:52 AM
mikecp's Avatar
i didn't know that.
so will the latch for the hood work properly if i extend my t-bar?
quirarte626
12
Aug 25, 2009 07:11 AM
killercrx91
Oct 26, 2008 04:56 PM
mr_willy_g
12
May 4, 2007 04:38 PM
gospeedgo1
Jan 11, 2007 10:45 AM
SLR ef9
19
Feb 20, 2006 10:23 AM
