Suspension & Brakes Theory, alignment, spring rates....
Fenders rolled, rubbing issue (tire sticks out?)
Old Jun 27, 2011 | 06:48 AM
talkJDM's Avatar
Icon2 Fenders rolled, rubbing issue (tire sticks out?)
Hey Guys,
Ever since I got my fenders rolled and my new rims installed (15x8 +25 Offset on 195/45's) I've been experiencing some rubbing issues whenever I make left turns.
The issue is with my passenger side, the tire rubs like crazy on the fender. The tire for some odd reason sticks out, even when the steering wheel is straight. I got the car aligned and everything is within spec and it still does this (running -2° camber on all four corners). It could be the slightest left turn and it will rub, the same turn to the right and there's absolutely no rubbing.
Below are pics, so you can see what I mean by the tire sticking out. The driver side sits flush as it should without issues, but the passenger side sticks out past the fender and bumper.
Looking at it for a while, I noticed the front corner of the passenger fender is bent slightly inward, which may be causing some sort of illusion that the tire is sticking out and at the same time making the fender that much closer to the tire. I honestly don't know; this is my educated guess.
I'm making this thread in hopes that maybe someone could help me out with this and maybe shine a little bit of insight as to what might be the cause for this. Again, I got it aligned, thinking it could've been that, but it's been set to specs and it still looks like this and rubs only on left turns.
DRIVER SIDE:
PASSENGER SIDE:
ALIGNMENT PRINTOUT (FRONT):
I appreciate any and all help you guys can provide.
Thanks,
Danny
Old Jun 27, 2011 | 10:27 AM
kyden's Avatar
Default Re: Fenders rolled, rubbing issue (tire sticks out?)
has the car been in an accident?
Old Jun 27, 2011 | 11:05 AM
talkJDM's Avatar
No wrecks, that's one of the reasons why I have no idea why this is happening ... I've also been the owner of the car since 2006, before then it had one other owner.
Old Jun 27, 2011 | 01:19 PM
texas6023's Avatar
When is the last time you replaced front struts? Are they original struts?
Old Jun 27, 2011 | 01:31 PM
talkJDM's Avatar
Not too long ago, they are not blown (if that's why you're inquiring). I have Koni Yellows with Ground Control Sleeve Coilovers + Extended Top Hats.
Old Jun 27, 2011 | 07:39 PM
toyomatt84's Avatar
Sanji
Unless you have some sort of deformity or inconsistency with your tires between each side of the car, this is an issue where you either have suspension or bodywork problems to contend with.
Old Jun 27, 2011 | 07:40 PM
talkJDM's Avatar
lol! okay ... thanks for moving the thread
Old Jun 28, 2011 | 06:20 PM
pwebb0207's Avatar
looks like the bumper might be pushed in a bit on that side
Old Jun 28, 2011 | 06:28 PM
talkJDM's Avatar
Thanks for input. I have an appointment with the guy who rolled my fenders tomorrow. He'll be taking a look at it and see what it could be, if it indeed is the fender then he'll roll it and maybe straighten it without deforming it. I'll post back after tomorrow to see if the issue is fixed.
Old Jul 3, 2011 | 09:31 AM
atleast-3's Avatar
Your may have never been in an accident, but if the front body panels were upgraded, it was proly aligned poorly. From what Im seeing the whole front end looks slightly to the drivers side of car. Pay attention to all your gaps. Could be a combonation of things.
Old Jul 3, 2011 | 04:15 PM
tsylican's Avatar
based on the fitment and alignment of the fenders matching up with the front bumper, it doesn't look OEM spec. Are you sure that either fenders/bumper may be aftermarket??
Old Jul 3, 2011 | 07:48 PM
talkJDM's Avatar
Parts are all OEM Honda, the only reason why they are like that is because I'm missing the Foam from the Front Bumper Support, so the bumper sags a little.
I finally met up with the guy who originally rolled my fenders. He was able to roll the passenger side more, enough for it not to rub when I make left turns. However the tire still sticks out.
I have not had a chance to try a different wheel on the passenger side to see if it sits the same way - been really busy, but I will try to do it this coming Tuesday and report back.
Old Jul 25, 2011 | 01:29 AM
theEGGmonsta's Avatar
maybe that one wheel is a different offset? happened to my friend somehow with his diamond racing wheels. one wheel was the same width, but different offset. i think it was by about 10mm and one side rub and he didnt find out the wheels werent the same until he noticed the rubbing. he contacted diamond racing and they sent him another wheel, said it was their mistake
Old Jul 25, 2011 | 06:20 AM
talkJDM's Avatar
I still have to check that, have been wayyy too busy to switch with another wheel and see fitment. They were all stamped +25 Offset though, but that could've been a printing/packaging mistake - it happens.
I did take it to get that side rolled a little more and now it doesn't rub as much, but still sticks out a bit.
mish__
Suspension & Brakes
Mar 3, 2013 12:08 PM
mish__
Mar 2, 2013 09:02 PM
oddmut
Honda Civic (2001 - 2005)
May 12, 2008 10:32 PM
alfaaay
Nov 11, 2003 11:32 AM
Uncle_Ben
Jun 27, 2002 07:53 AM
