91 accord gauges, clock, seatbelts stopped workin and car sputters at higher speed
Have a 91 honda accord dx engine vin#6 and the other day while driving the whole instrument cluster stopped working... all gauges and seatbelts dont work anymore... also when u get near 4th gear the car sputters and wont go any faster you have to downshift and drive in lower gear... car seems to have lagged pick up speed and also likes to cut out while driving down the road... sucks the fuses arent really in seperate fuses... not sure if it is bad ground or what... please help!!! Thanks!
Did you happen to turn on the lights? The same thing has been happening to me but only when I turn on the lights. When I turn the lights on the rpm, speedometer, and radio all short out then the car starts to sputter and eventually dies.
I didnt have that prob... i went through all the fuses and found the underdash fuse#1 i believe (the radio 10amp fuse nnext to 15 amp ecu fuse was blown) that fuse controls everything that wasnt working... also had multiple fuses installed had wrong amperages so replaced with correct ones... thanks for the heads up about the lights... :-)
zann121
Jun 6, 2009 05:01 PM
