T3/T4 Vacuum Line HELP!!!!
Old Jun 26, 2011 | 01:06 AM
Joeynapp's Avatar
Default T3/T4 Vacuum Line HELP!!!!
I recently rebuilt my D16 I bought it in pieces and rebuild it from the ground up. and have no idea how to run the vacuum lines! If you have a visual diagram that would be best if not thats fine. I'm running a boost controller. Been looking at pictures and videos for the past week and cant find anything! Any help is appreciated!
Old Jun 26, 2011 | 03:31 AM
NACvicSi's Avatar
Default Re: T3/T4 Vacuum Line HELP!!!!
Ok so what exactly are you looking for because your title and post say two different things?
Old Jun 26, 2011 | 03:43 AM
grumblemarc's Avatar
The Grumpiest
Check the link in my sig if o need to know how to run vacuum lines to your turbo kit. Otherwise buy a manual for your car.
Old Jun 26, 2011 | 06:38 AM
EsotericImage's Avatar
Retired Moderator
ditch the manual boost controller..
run the line from compressor to the wastegate. Done!
If you want a boost controller, use an electric one and your tuner will set it up.
Old Jun 26, 2011 | 07:46 AM
Schister66's Avatar
Man U FTW
I'm not sure if this will help or not, but if you still have questions, ask...vacuum lines can be tricky the first time
Old Jun 26, 2011 | 11:30 AM
Joeynapp's Avatar
Thank you schister! it did help. I'm going to post some pictures of it tonight because my set up is a little different.
Old Jun 26, 2011 | 11:33 AM
Joeynapp's Avatar
and yea turbo vacuum lines. Also the how to turbo charge you civic is good too thanks!
Old Jun 26, 2011 | 02:36 PM
Schister66's Avatar
Man U FTW
Yeah, post pictures of your setup and i can help you out. I can MS Paint it for you as a guide
mr.nguyen
Jul 9, 2009 12:15 PM
Unseen Racer
Jan 14, 2009 06:03 PM
South Bay Surfer
Jun 2, 2008 09:00 PM
hondamonkey
Nov 24, 2007 03:55 PM
SwIntegraB16
Apr 3, 2005 10:27 PM
