need help with my 1994 accord
Old Jun 25, 2011 | 09:53 PM
herbalistX's Avatar
Default need help with my 1994 accord
So my dashboard and tail lights went out all of the sudden.....I checked the bulbs- they're not burnt out; I checked the "small lights" fuses- they're not blown but I changed them anyway- no there's no popping sound; I saw that this is fairly common in connection with a new stereo which I have- couldn't figure out which wire was the "dimmer control wire" (no owner's manual)- so I disconnected the whole thing; I even tried removing the negetive contact on the battery and then reconnecting to reset the electrical. ALL NO JOY!!!!! i work at night and commute roughly 50 miles, I really need this remedied ASAP any ideas?
Old Jun 25, 2011 | 10:28 PM
bzmotoninja1983's Avatar
Default Re: need help with my 1994 accord
did you cut the old plug out? if you did, did you keep it? if you kept it or even if you didnt, go to a parts store, locate a stereo install harness, find out which one is foe the dimmer.
now that is out of the way, if you still have the old plug, locate the location of said illumination wire. if you cur the plug out, locate the wire that matches. ....... boom, you should be on the right track. now, if you were anything like me, you might have tossed that one out. go to a junk yard, either cut one out, with space to spare(so you can splice into your setup, or remember the color combo for said wire.....
Bz
Old Jun 26, 2011 | 07:46 AM
76 camaro car's Avatar
Did you replace the fuses under the hood also?
Old Jul 4, 2011 | 11:05 PM
herbalistX's Avatar
so it turns out that the tail light wires were burnt from poor grounding and a depleted battery. i had the wiring redone and the battery charged and everything is working great!!!
Old Jul 5, 2011 | 04:18 AM
nus_dogg's Avatar
Glad you fixed it!
mutiny93
Mar 22, 2011 05:20 PM
AFTricker
Jan 1, 2010 05:17 PM
ShakesTheKlown
Mar 29, 2004 09:19 AM
accord4banger
Jul 21, 2003 12:11 PM
