Runing out of Brake With Wilwood on EK
I am curently runing Wilwood 4 piston 12.25 inch with HP+ in front and integra brake with HP+ for the rear...
Problem is that is run out of brake quickly , Not that pedal goes to the floor , but they just fade.....i dont want to see what is going to hapen at the track.... ( laping not drag) I tought they would better than that on a 2200 lbs car....
Any sugestion on A better Pads than the HP+ ?
Try track pads with higher operating temperatures. HP+ tries to be street and track, not great at either. I am not sure what size you use. I like Cobalt Friction, others Carbotech, etc. Many opinions on brands, but track pads, and I will assume that you have high temperature new fluid.
What pads are you running? If your running a really mild street pad your going to always run into this issue. The wilwood calipers are great for the money and I am sure your pad and even fluid is your main issue
sierrahiker8
16
Sep 12, 2012 06:41 AM
