have a frankinstien swap 89 ef need wire harness help.
i bought it and the wire harness was completely jacked looking like a rats nest and i took it out. Can anyone help me clean it up and get it running.
its mostly the diver side of the harness that is jacked up. it goes to the plug by the injector resistor box and injectors. those are the wires that are rat nested. i dont know if the vtec is wired in the harness are never hooked up. i cant but pics up cause i have the harness off the get done hopeing to fix this problem. the guy isn't that good at wireing.
Start with this: what model is the car? DX, SI, or true jdm??? This would help because the dx and si do not come wired for vtec. If it's a true jdm harness I can repair it for you. Pm me if interested
its a dx. i found out a major problem on it. the fuel pump is not working when i turn the key on. i tested it with the plug under the seat. it worked and then tired the relay and nothing. its a brand new relay to.
tijuanavtec
11
Dec 8, 2009 04:32 PM
DOHCintegra91
Sep 24, 2006 08:29 AM
LSvtechatch97
Oct 15, 2004 04:30 AM
