Wetsanding and Buffing Paint Enamel?
Old Jun 25, 2011 | 03:54 PM
f20cmx5's Avatar
Default Wetsanding and Buffing Paint Enamel?
My friend told me that I can't wetsand and buff my 91 crx with original paint because they used a different painting process in that time. He says they used single layer paint enamel with the clear coat mixed in as opposed to modern day paint where they spray a base coat then clear. Is he right? Or can I carefully wetsand and buff my paint? Thanks
Old Jun 25, 2011 | 03:56 PM
f20cmx5's Avatar
Default Re: Wetsanding and Buffing Paint Enamel?
I want to do this only to my quarter where I did some body work. I sprayed some rattle can perfect match paint, but it has an almost unnoticeable paint line where I taped off. I want to wetsand the entire quarter then buff it to blend it together. Does that sound like it will work?
Old Jun 25, 2011 | 06:34 PM
nikez4me's Avatar
post a pic and ill let you know
Old Jun 25, 2011 | 06:51 PM
f20cmx5's Avatar
I will when I get ahold of a camera.
Anybody wetsand their old original paint?
Old Jun 25, 2011 | 07:19 PM
Hawkze_2.3's Avatar
If the paint is in fact single stage, it can be buffed if it is a solid color, but it cannot be buffed if it is a metallic paint.
Old Jun 26, 2011 | 09:39 PM
shocker911's Avatar
your car is 99% paint and clear....UNLESS your car was re-painted and they used single stage
Old Jul 16, 2011 | 05:12 AM
f20cmx5's Avatar
It has the original paint except for on the quarter panel where I want to blend the spray can paint with the original. Can that be done through wet sanding and buffing?
TracerAcer2.2L
Paint and Body
Dec 25, 2015 02:23 PM
tweensquirt
Acura TSX
Mar 12, 2012 05:58 AM
curtie94
Sep 28, 2011 11:23 PM
self_made
Sep 17, 2002 07:34 PM
