96 2.2 vtech misfire between 2100 2800rpm
Old Jun 25, 2011 | 06:38 AM
dexmek's Avatar
Default 96 2.2 vtech misfire between 2100 2800rpm
I'm at witts end i got a 96 accord coupe for my boy (its frickin awsome)has worked like a charm but now sends code for cyl #2 misfire and misses in between 2100 and 2800 rpm and perfect the rest of the time.
all ignition components new but still the same any tips???
Old Jun 25, 2011 | 07:36 AM
2fast4u831's Avatar
I'm really 2slow
Default Re: 96 2.2 vtech misfire between 2100 2800rpm
vtech is interfering with the electronics. change the vtech.
Old Jun 25, 2011 | 02:15 PM
dexmek's Avatar
FOR REAL?
I never would of guessed that. how or why is it doing this?
there are many notions as to this but none i realy trust ranging from intake needs cleaning,egr,valve lash to injectors plugged.
you seem very certain can i ask how your so certain?
dont misunderstand me im very thankful but as a mechanic with many years experience i am curious.
Old Jun 27, 2011 | 04:48 AM
yourboyluigi09's Avatar
idk about the vtec interfering but we'll wait on buddy^ to explain how it interferes...i'd say check ur spark plugs nd wires first..maybe distributor..start with the small things like ur doing...maybe its something simple
Old Jun 27, 2011 | 05:32 AM
h2point2's Avatar
i can tell you, i had a 90 accord i put a 93 jdm h22 into and it always had this damn problem and i could not find a fix for it. would run fine untill about 2500 the putt and sputter then after like 3200 it would go fine again.
Old Jun 27, 2011 | 06:25 AM
civickiller's Avatar
That's a smart *** remark because it's vtec not vtech
what exactly did u change?
Clogged fuel injector?
Old Jun 27, 2011 | 03:28 PM
dexmek's Avatar
changed all ign parts, timingbelt ,valve lash,did not change module in dist,but i cant see how it could be that nor the pickup in the dist. changed holes for inj, but still codes for cyl 2 cleaned egr valve.removed and cleaned vtec valve.all negative results,
got a very fiesable tip that states there is a plate on the top of the intake and under it are ports for egr to each cyl and they can get plugged,best tip ive had yet but im still up to suggestions,
Old Jun 27, 2011 | 03:58 PM
turbociv910's Avatar
run premium for a week and re check
Old Jun 29, 2011 | 12:32 AM
rd91sib18c5r's Avatar
Sounds like the igniter, thats all thats left to change.
Codyaz
Mar 28, 2015 08:07 PM
HAB22
Jun 4, 2011 06:47 AM
newguy11
Feb 10, 2011 02:38 PM
scythe88
Mar 13, 2010 02:17 PM
